So where do we get our rotor for cheap?
![](/forums/images/ranks/11k.gif)
CI 3-5-6-7-8 Veteran
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I know you can get our rotors for cheap, but is it from NAPA, Auto Zone, Advanced, etc.?
Thanks,
Brian :cheers:
Thanks,
Brian :cheers:
![](/forums/images/ranks/3k-4k.gif)
![](/forums/images/ranks/4k-5k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![](/forums/images/ranks/100-500.gif)
Check out Advance Auto Parts they have some slotted and cross drilled rotors for a decent price, also ceramic pads. I am planning on using them when I do mine later this year.
At NAPA online, they didnt have pics. Are these rotors really OEM replacements as far as quality and performance? Or is it safe to say with these rotors, "you get what you pay for"?
At first I thought this was too good to be true but quite a few forum members have reported good results with them.
Click on image to enlarge:
![](http://member.newsguy.com/~rmoburg/jpegs/Corvette/$19%20Rotor.jpg)
![](/forums/images/ranks/5k-6k.gif)
I got mine @ NAPA for ~$25 each. The important thing to note on these, as I'm guessing would be the case with any other rotor than GM, is that the hats are not painted and will quickly develop surface rust and it does not look good. Paint the hats prior to mounting. Other than that they are as good as any other rotor (non slotted or drilled) as far as I can tell. :thumbs:
I used the two part brake caliper paint on my hats and 5K later it still looks good
![](/forums/images/ranks/2k-3k.gif)
Check the for sale sections, some guys take these off right away and put aftermarkets on. I've seen them sold really cheap there.
That's a good idea.... I'm going to change pads soon and if I need rotors I'll grab a set. I don't think I need rotors they don't have much hard use on them.
