Someone with service manual please help.
Old Feb 26, 2004 | 11:32 AM
70 LS1's Avatar
70 LS1
Default Someone with service manual please help.
Can someone check their service manual and see what the resistance for the wheel speed sensors is supposed to be?
thanks
Old Feb 26, 2004 | 12:01 PM
BlackZ06's Avatar
BlackZ06
Default Re: Someone with service manual please help. (70 LS1)
My 2001 manual says 850-1350 ohms
Steve
Old Feb 26, 2004 | 12:43 PM
70 LS1's Avatar
70 LS1
Default Re: Someone with service manual please help. (BlackZ06)
Thanks,
is that for both front and rear?
Old Feb 26, 2004 | 02:01 PM
BlackZ06's Avatar
BlackZ06
Correct, the sensors are the same on all four wheels - again this is based on the 2001 manual.
Steve
Old Feb 26, 2004 | 02:26 PM
70 LS1's Avatar
70 LS1
Thanks Steve.
Is there any other info in the book about them? frequency? single or multiple pole magnetic pickup? # of pulses per revolution? Anything else would be helpful.
Old Feb 26, 2004 | 03:31 PM
BlackZ06's Avatar
BlackZ06
Unfortunately the manual doesn't give a lot of detail ...
"As the wheel spins, the wheel speed sensor produces an AC signal. The EBCM uses the frequency of the AC signal to calculate the wheel speed."
I guess they figure this is all Mr. Goodwrench needs to know, either the EBCM is getting a valid signal, or not. If not, either the wiring or the sensor is faulty.
Only info shown is that in testing for a bad sensor, a sensor is tested in two ways:
1) Wheel stationary - measure resistance ( Allowed value range listed is 850 - 1350 ohms)
2) Wheel rotating - AC voltage should be 100 mV
If the sensor doesn't pass those two tests, then the fix is to replace it. If the testing shows a valid signal at the pin outs for the EBCM, then the fix is to replace the EBCM. Makes it simple for the mechanic, but not much help for someone trying to reverse engineer what the EBCM and sensors are up to.
Good luck,
Steve :cheers:
Old Feb 26, 2004 | 04:16 PM
70 LS1's Avatar
70 LS1
Thanks Steve,
that actually helps a lot.
To Someone with service manual please help.
