Which Brake Fluid..........
Old Feb 26, 2004 | 07:57 PM
Cruises's Avatar
Cruises
Default Which Brake Fluid..........
I am changing over to the Goodrich Brake Lines, Speed Bleeders, and naturally the next question is changing the brake fluid. I considered synthetic but DOT 5 doesn't seem to be in favor for a number of reasons. Is DOT 3 - 4 still the standard ?
Old Feb 26, 2004 | 08:38 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Default Re: Which Brake Fluid.......... (Cruises)
DOT 3 is the factory fill and recommended fluid.
DOT 4 is compatible with DOT 3, just higher boiling points (better).
DOT 5 is NOT compatible with 3&4, and does not work in cars with ABS brakes.
Unless you're doing very serious racing, just go with a good DOT4 such as Valvoline synthetic or ATE Superblue.
Good luck.
Old Feb 26, 2004 | 09:48 PM
Cruises's Avatar
Cruises
Default Re: Which Brake Fluid.......... (SDVette)
Thanks, exactly the info I was looking for. :cheers:
Old Feb 26, 2004 | 10:09 PM
bk's Avatar
bk
ATE is great stuff and reasonably priced.
Old Feb 26, 2004 | 11:53 PM
AZGASSER's Avatar
AZGASSER
:withstupid:
I am using Valvoline Synthetic for the last 6 months and like it and have had no problems. Go with a dot4 synthetic and you cant go wrong. I did the speedbleeders and the goodridge lines this weekend. I was inpressed by the improved braking response! :crazy:
Old Feb 27, 2004 | 03:28 AM
Richin Chicago's Avatar
Richin Chicago
ATE Superblue or Amber. I really like this stuff. It seems to be so stable and durable that my bleeds after a track day never show bubbles or discoloration. I used to change my fluid a lot now I do it annually.
http://www.autotechnic.net/store/asp...asp?product=70
Old Feb 27, 2004 | 06:16 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It's Valvoline synthetic for me too. It was recommended to me by a local 'Vette shop.
To Which Brake Fluid..........
