Cut Corsa over-the-axle pipe for alignment???
Old Feb 27, 2004 | 08:03 AM
jimk's Avatar
jimk
Default Cut Corsa over-the-axle pipe for alignment???
Just installed a Corsa Indy catback system (on a M6) and while I can easily align the tips horizontally, both have a slight tilt in towards each other. I have bottomed out the over-the-axle pipe into the muffler but still have a slight tilt-in. Has anyone needed to cut the pipe a little shorter so it allows the muffler to point straight back? I did not have this issue when I intalled a Corsa Touring on my A4.
Old Feb 27, 2004 | 08:20 AM
Mr. C's 5's Avatar
Mr. C's 5
Default Re: Cut Corsa over-the-axle pipe for alignment??? (jimk)
I've had three differnt Corsa systems on my car without any problems. Before you cut anything, I would suggest you call Corsa and see what they say. - C.
Old Feb 27, 2004 | 08:32 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I had my Corsa on two different cars, none of which needed and cutting to fit right... just bolting...
Old Feb 27, 2004 | 08:37 AM
HEB's Avatar
HEB
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Cut Corsa over-the-axle pipe for alignment??? (Mr. C's 5)
:iagree: The over the axle pipe is in two pieces,I had to make some adjustments on alinement by loosening the clamps on the axle pipes on my Corsa Daytonas.
[Modified by HEB, 7:44 AM 2/27/2004]
Old Feb 27, 2004 | 10:05 AM
georgec114's Avatar
georgec114
Default Re: Cut Corsa over-the-axle pipe for alignment??? (HEB)
The tips on my first set of Daytonas were incorrectly welded.
Corsa exchanged them without a problem.
But once the new ones were on, there was still a little misalignment.
Talked with West Coast Corvettes and he said that on occasion, they
would need to heat the tip backplate a little and make adjustments.
I didn't need to do that as there is enough "wiggle room" to slightly
bend that backplate with a little force. They lined up just fine.
...George
To Cut Corsa over-the-axle pipe for alignment???
