Help, stuck rear rotor...
Old Feb 27, 2004 | 08:50 PM
nericreations's Avatar
nericreations
Default Help, stuck rear rotor...
I tried using search function wasn't working, anyway I'm changing my stock rotors to cross/dimpled, but my left rear seems to be stuck at the bottom right :confused: , any suggestions as too what I'm missing, or a site with how-to?? Thanks!
Neri
Old Feb 27, 2004 | 09:04 PM
silverz06vette's Avatar
silverz06vette
Default Re: Help, stuck rear rotor... (nericreations)
I take it that the e-brake is off. Try to cycle the e-brake a couple of times.
Old Feb 27, 2004 | 09:17 PM
nericreations
Default Re: Help, stuck rear rotor... (silverz06vette)
Worked!! Thanks!!! :cheers:
Old Feb 27, 2004 | 09:18 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Been there done that, parking brake it is........ :yesnod:
Bob
Old Feb 27, 2004 | 09:23 PM
Cruises's Avatar
Cruises
Are the " crossed dimpled rotors " the new more efficient design ? :confused: :confused:
Old Feb 27, 2004 | 10:40 PM
nericreations
Default Re: Help, stuck rear rotor... (Cruises)
just dimpled instead of drilled to prevent cracking....anyway I have a new problem, the ebrake came off, and there seems to be a pin to hold it to the wheel bearing, how do I re attach??!? Please help :confused:
To Help, stuck rear rotor...
