1998 A4 differential replacement
Old Feb 27, 2004 | 08:51 PM
jrburb's Avatar
jrburb
Default 1998 A4 differential replacement
Is there a difference between the differential from a A4 vs 6 speed.
Why I ask? I bought a complete 3.15 unit and the mechanic who in installing it says it's for a 6speed and won't work with an automatic.
Old Feb 27, 2004 | 09:05 PM
hightest's Avatar
hightest
Default Re: 1998 A4 differential replacement (jrburb)
The carrier case between the 3.15 and up (3.42, 3.73, etc.) are all the same six speed or A4. The only carrier that is different is the 2.73. The 2.73 cases aren't as well reinforced.
Any of these C5 corvette differentials (Getrag) will work for your 98. If your mechanic doesn't know that, I suggest finding one who knows Corvette's. This will at least give you some peace of mind.
Old Feb 27, 2004 | 09:11 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
First off, 6 speed C5s don't come with 3.15s. If its a 3.15 differential, then it came off of, and goes on to, an automatic.
[Modified by EB20003, 8:13 PM 2/27/2004]
Old Feb 27, 2004 | 09:17 PM
jrburb's Avatar
jrburb
Default Re: 1998 A4 differential replacement (hightest)
The mechanic said the face place on the differential in the car where it mates to the transmission is different. the current unit is the original 2.73's. The mechanis knows vette he builds race units for T1 class, but they are all 6 speeds.
Old Feb 27, 2004 | 10:42 PM
Mike Mercury's Avatar
Mike Mercury
the face plate is called a "seal plate". It is a 6" round disk that's removeable from the A4 diff and can be re-used on any C5 differential.
Depending on the cars original mileage; you might want to replace the two seals that are located on the seal plate. The part numbers fior these seals are located on this page:
http://mikemercury.home.att.net/342.htm
here is a pic of the carrier with the seal plate still installed:
Again; the plate is a seperate piece that can be removed and ported-over to any other C5 carrier.
[Modified by Mike Mercury, 10:46 PM 2/27/2004]
Old Feb 27, 2004 | 10:44 PM
'06 Quicksilver Z06
Can he swap the faceplates?
Oops, I guess so. Mike would know.
I was also reading Mike V's write up where he says;
"To remove the differential plate, thats the plate that goes between the trans and the differential, use a large wide blade screw driver thru the center hole. Insert at an angle between the plate and the differential far enough so that when you turn it you are touching the plate and not the seal. Turn the screwdriver at 3 or 4 different areas to pop out the plate"
I too will be doing this swap in the future and am trying to learn as much as I can between now and then.
[Modified by EB20003, 9:55 PM 2/27/2004]
Old Feb 28, 2004 | 07:33 AM
jrburb's Avatar
jrburb
Default Re: 1998 A4 differential replacement (Mike Mercury)
Mike,
Thanks for all your help. I now know how to proceed. :hurray:
Old Feb 28, 2004 | 08:29 AM
ndirishr1's Avatar
ndirishr1
As the replies above suggest your mechanic needs a little more knowledge. Auto's come with 2.73s and 3.15s, 6-spds are 3.42s. They are I believe interchangable. I'm having 4.10s built for my 2000 auto. When the 3.15s come out of it I will have it rebuilt and put in my 2001 6spd. I will then keep the 3.42 from my 2001 in case I ever sell either car and want to pull the 4.10s for another.
Old Feb 28, 2004 | 10:41 AM
Mike Mercury
Default Re: 1998 A4 differential replacement (EB20003)
I used a small pry-bar... similar to the one pictured here:
the pic makes the pry-bar look larger than it really is.
Going in from the center seal area - placing the pry bar between the seal plate and the carriers front casting face.
Just a little at a time as you move the pry bar around the circumference.
Re-installation has cause some a problem. Mainly; the outer "O" ring can get dislodged from the small slot in the plated outer edge. Placing a thin amount of diff fluid on the carriers "lip" surface (where the plates "O" ring makes contact) allows it to go in much easier.
Good luck and keep up posted.
[Modified by Mike Mercury, 10:43 AM 2/28/2004]
To 1998 A4 differential replacement
