HELP! Dash Removal
Old Feb 28, 2004 | 05:31 AM
syndicate's Avatar
syndicate
Default HELP! Dash Removal
I'm trying to remove my dash and i am stuck. I removed the 3 screws in the glove box, 1 on passenger side, the ones around the radio, and the ones around the steering wheel and instrument cluster. It appears to be stuck around the defrost vent on the dash because i can lift the front up. I looked but couldn't figure out how to remove that vent. Any ideas guys???
Old Feb 28, 2004 | 08:59 AM
racetchr's Avatar
racetchr
Default Re: HELP! Dash Removal (syndicate)
I would like to know this too. :rolleyes:
Old Feb 28, 2004 | 09:29 AM
DocToss's Avatar
DocToss
Have you looked at this instruction link?
http://www.thelapd.com/bezel.htm
Old Feb 28, 2004 | 09:47 AM
syndicate's Avatar
syndicate
Default Re: HELP! Dash Removal (DocToss)
Thanks for the link. But it seems to be stuck in the large vent in the center of the dash so i'm still stuck. :( any other ideas?
Old Feb 28, 2004 | 09:52 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Try this link. Joshker99 gives excellent instructions on how remove the C5 dash.
http://joshker99.home.comcast.net/hudinstall2.htm Good luck. :)
Old Feb 28, 2004 | 10:36 AM
syndicate's Avatar
syndicate
Default Re: HELP! Dash Removal (BiggieBoy)
Thanks a lot man. I really appreciate the info.
Old Feb 28, 2004 | 11:37 AM
3X2's Avatar
3X2
Going from memory here. You have the glove box, center console and left knee bolster removed. Let's see.......... 7mm screws- 1 located at the left of the column on that silver bracket, 2 vertically from the instrument cluster into the dash pad, 3 around the radio/hvac control, 1 next ti the glove box latch, 2 under the defroster grille, 1 each side under the a-pillar moldings. I think that's all of them!
Mark
Old Feb 29, 2004 | 09:43 AM
BiggieBoy's Avatar
BiggieBoy
You are welcome... :thumbs:
To HELP! Dash Removal
