Do I need an X Pipe?
Feb 28, 2004 | 03:23 PM
St. Jude Donor '08
I'm plannig on getting Borla's installed at Ecklers in April. Do I need the X pipe ?
[Modified by TowerMan, 5:39 PM 3/1/2004]
Feb 28, 2004 | 04:49 PM
Re: Do I need an X Pipe? (TowerMan)
Some claim more HP with the X-Pipe, Bassani has a good one, where
it helps a lot is the gurgal and poping sound when you let of the gas. :cheers:
Feb 28, 2004 | 06:31 PM
Re: Do I need an X Pipe? (lar66BB)
:iagree: The biggest difference it made on mine was that it eliminated about 90% of the popping and gurling on deceleration. I recommend the X-pipe unless you like the added sounds on deceleration. The X-pipe seemed to smooth the exhause out a little.
Feb 28, 2004 | 07:30 PM
Re: Do I need an X Pipe? (BlueDream)
:iagree:
Feb 28, 2004 | 09:28 PM
Quote:
I'm planning on getting Borla's installed at Ecklers in April. Do I need the X pipe ?
Need.. No.. Should you get one? YES.. At least IMHO. I find my car much more enjoyable to drive with the addition of the X-Pipe.
Cheers,
Mark
Feb 29, 2004 | 09:22 PM
St. Jude Donor '08
Re: Do I need an X Pipe? (mdhmi)
I thank you all for the replies. Now to find an X pipe and explain the need to wife- she's usually approving :D
Feb 29, 2004 | 09:32 PM
Quote:
... Now to find an X pipe and explain the need to wife- she's usually approving :D
I'm sure she will prefer to ride in a car with substantially reduced popping noise on deceleration. Tell her the x-pipe is for her benefit. : )
Mark
Mar 1, 2004 | 03:04 AM
Dad just got the Borla Twin Tip stingers installed with no x-pipe. They sound awesome. Very little popping on deceleration (we were both kinda sad about that but oh well). They produce no noise in the car while cruising. I don't think you need the x-pipe.
Mar 1, 2004 | 04:52 AM
Re: Do I need an X Pipe? (BigBlue)
I've driven one with stingers and no X pipe and it sounded great. I actually liked the back firing noises it made on downshifts. :cool:
Mar 1, 2004 | 05:18 AM
Cheers,
Mark
I whole heartedly agree. I have an '04 Z and after the X-pipe install, the car doesn't sound like it's about to fall apart anymore.
Here's a pic of what I had installed: MagnaFlow X-pipe:
Have fun and be safe and good luck on your decision~!!
Mar 1, 2004 | 10:47 PM
St. Jude Donor '03-'04-'05
Re: Do I need an X Pipe? (winemeup911)
We all need X-Pipe ! Best,
mtv
Mar 4, 2004 | 12:08 AM
There are two systems that do not need an X-pipe. One is the Z06 Ti's and the other is Magnaflow. While it does stop the rat-a-tat-tat on deceleration, it turns the volume down. The system that needs it most is Corsa. As for HP gain, don't expect anything and you won't be disappointed.
Dan
Mar 4, 2004 | 12:26 AM
I put a x-pipe on mine and gained hp. The x-pipe also made a diffence in the sound. I would say it is worth it
Mar 4, 2004 | 08:27 AM
Repeat after me "If it is a MOD I need it", just keep saying that over and over, you will never have a doubt in your mind again> :jester
Mar 4, 2004 | 08:43 AM
Re: Do I need an X Pipe? (CAPN17)
The xpipe will also eliminate the motorboat sounding idle on the corsa indy's. I still have some popping on decelleration after the xpipe on my borlas but I love it.
