LS1 edit?
Old Feb 29, 2004 | 02:01 AM
Bigblockquad's Avatar
Bigblockquad
Default LS1 edit?
Can anybody explain what LS1 edit is and what parameters it affects.
Sorry, still used to Buick GN's :D
[Modified by Bigblockquad, 7:04 AM 2/29/2004]
Old Feb 29, 2004 | 02:04 AM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: LS1 edit? (Bigblockquad)
try c-5 scan and tune, you will get more respone over at that site. :yesnod:
good luck :thumbs:
Old Feb 29, 2004 | 02:11 AM
Bigblockquad
Default Re: LS1 edit? (MC TORCH RED)
Thanks, I did that.
Old Feb 29, 2004 | 02:24 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
The PCM/ECU in our cars provides OBDII/diagnostics and engine/powertrain management.
Ls1Edit allows us to "Edit" the various lookup tables in the PCM as well as modify/turn off-on many diagnostic tests ( as well as their associated codes).
Some of the functions we can Edit are Timing and Fueling as well as the transmission shift points etc.
In order to evaluate the need for and result of Editing you will need a scanner to log various parameters ( RPM, MAP, MAF, LTFTs,O2 V etc.) and evaluate performance. EFILive and Autotap are the most popular. EFILive 6 is the best product IMHO. :yesnod:
Hope this helps some.
Old Feb 29, 2004 | 01:30 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Hi Bigblockquad,
Gives us a call and ask for Al…he can discuss the parameters more completely….. But, in the meantime, LS1 Edit calibrates, air- fuel – spark – timing, through software and writes to the PCM.
Additional features in LS1 edit include, but are no limited to;
Fans on/off temps
Transmission shift points
Speed and RPM limiters
VE tables for speed density tuning
MAF scaling
List goes on and on…
Thanks,
Shawn
To LS1 edit?
