Wheel size issues??
Old Mar 1, 2004 | 06:11 PM
GAS's Avatar
GAS
Default Wheel size issues??
I am about to order the polished Z06 wheels in 18x9.5 front and 19x11 rear. Will I have any issues with those sizes?
[Modified by GAS, 10:49 PM 3/2/2004]
Old Mar 2, 2004 | 05:08 PM
FKING1's Avatar
FKING1
Default Re: Wheel size issues?? (GAS)
Have 18x9.5 frt & 18x10.5 rr, no issues. 11's should also be OK.
Fred K. :hat
Old Mar 2, 2004 | 05:16 PM
jawski's Avatar
jawski
Default Re: Wheel size issues?? (FKING1)
Fred K. :hat
:iagree:
Old Mar 2, 2004 | 05:48 PM
MrBill's Avatar
MrBill
10 x 11 rear? What rubber do you plan on putting back there? If you meant 19x11, then those are the sizes I just ordered...i'm going with Michellin Pilot Sports on mine.
Old Mar 2, 2004 | 05:53 PM
GAS's Avatar
GAS
Default Re: Wheel size issues?? (MrBill)
I did mean 19x11. I just got a severe case of sticker shock from two tire dealers. Yokahama AVS Sport was $1,286.00 for all four and Michelin Pilot Sports were $1,765.00 for all four!!!
Old Mar 2, 2004 | 05:59 PM
YELLOHHH's Avatar
YELLOHHH
No.
What size tires do you plan to use?
Old Mar 2, 2004 | 06:23 PM
GAS's Avatar
GAS
Default Re: Wheel size issues?? (YELLOHHH)
275/35/18 fronts and 295/35/19 rears. Wanted 305/30/19 for the rear but am having trouble finding them.
Old Mar 2, 2004 | 06:36 PM
joe03z06's Avatar
joe03z06
call john at ccw he should have 305's
Old Mar 2, 2004 | 06:45 PM
GAS's Avatar
GAS
Default Re: Wheel size issues?? (joe03z06)
ccw is?????
Old Mar 2, 2004 | 07:00 PM
YELLOHHH's Avatar
YELLOHHH
You should have no problem, but I would hold out for the 305/30's. Not only will they look and handle better, but it will keep your front/rear stagger ratio closer to stock. If you can't find them, I would go 275/30 in the front, not 35's. Good luck, and :cheers: on a killer set up.
Old Mar 2, 2004 | 07:08 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Who makes a 275/30/18?? :skep: I think it would be a little too short if it did exist.
I would suggest the 265/35/18 for the front if you use the 305/30/19 rears. Pirelli is the only one that makes that 305 size that I know of. Tirerack is currently showing "low stock" on their website for the 305's..have you tried contacting them yet?
:cheers:
Old Mar 3, 2004 | 06:48 AM
Should have no problems other than paying for the things. :D
Old Mar 3, 2004 | 10:22 AM
YELLOHHH's Avatar
YELLOHHH
Default Re: Wheel size issues?? (Y2Kvert4me)
:cheers:
You are correct, that size does not exist. I was on a tire diameter site when I typed that. I was just looking at overall diameter between the front and rear tires. 265/35 would be great. That's what I run now and they work great. I would still however go for the 305's over the 295's.
Old Mar 3, 2004 | 02:40 PM
Sportsdude's Avatar
Sportsdude
275/30/19 and 305/25/20 Conti 2 cost me $1400.00. Rim size that you had mentioned will be fine.
Old Mar 3, 2004 | 09:00 PM
South Tex Vette's Avatar
South Tex Vette
Default Re: Wheel size issues?? (Sportsdude)
I have had my P Zero's 275/35/18 - 305/30/19 for three weeks. It was hard to find a tire size combo with the 19" rear and keep the .7 of an inch difference for the Active Handling System(doing the math on all of the availabe tire sizes & combinations makes you go blind). P-Zero's are dead quiet and alot better traction compared to the old run flats. The only thing I don't like is the rear tire looks kinda low rider with the 11" wheel(needs more tire width). ZO6 Motorsport wheels $1700, P-Zero's $1600.
If you could find a 315 with the correct diamter let me know.
[Modified by South Tex Vette, 8:00 PM 3/3/2004]
Old Mar 4, 2004 | 09:16 AM
GAS's Avatar
GAS
Default Re: Wheel size issues?? (South Tex Vette)
Are you saying the rim appears to wide for the tire. I thought I read somewhere the tread width was about 10.2 inches and I am having reservations the 11 inch rim would appear to wide! :banghead:
Old Mar 5, 2004 | 12:36 AM
South Tex Vette
Yes, They look like their streching to stay on the bead. , but I could not find another tire with that width and correct Tire Diameter
BUT WHEN YOU PULL THE WHEEL OUT OF THE BOX. HLY ST IT LOOKS HUGE. WHEN I TRIED TO HEAT UP THE TIRES AT THE TRACK, THE CAR BOGGED ALITTLE BEFORE I REALIZIED HOW MUCH MORE TRACTION i WAS GETTING. hOWEVER LAUNCH WITH A yANK 32OO AND TRACTION IS GONE.
[Modified by South Tex Vette, 11:39 PM 3/4/2004]
[Modified by South Tex Vette, 6:17 PM 3/7/2004]
To Wheel size issues??
