Suspension creaking
Old Mar 1, 2004 | 09:30 PM
bakerwt's Avatar
bakerwt
3rd Gear
Default Suspension creaking
My 99 C5 sounds like a creaky old wagon when the temperatures drop below freezing. Any suggestions as to how this can be remedied would be appreciated.
Terry
:seeya
Old Mar 1, 2004 | 10:06 PM
Racer1x's Avatar
Racer1x
Default Re: Suspension creaking (bakerwt)
1st off welcome to the forum :seeya
Its probably your anti-sway bar bushings and or end links (if they are the original plastic links).I believe the front bushing are not supposed to be lubed so replace them, and lube the rears.
Old Mar 2, 2004 | 04:37 AM
te51cle's Avatar
te51cle
I've been noticing a similar creaking for a while too. Sounds like its time to upgrade to a Hotchkis or something like that at the same time !
Old Mar 2, 2004 | 04:47 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Suspension creaking (te51cle)
Is your car lowered at all? My car began creaking after I lowered my car. Kaley
Old Mar 2, 2004 | 04:53 PM
Monster231's Avatar
Monster231
Default Re: Suspension creaking (2C5only21)
Im gonna have the dealer repalce my entire suspension because of the creaking
Old Mar 2, 2004 | 05:08 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Suspension creaking (Monster231)
Get ready for a huge bill
Old Mar 2, 2004 | 05:12 PM
TGrits10's Avatar
TGrits10
Hey no need to go squirrel hunting with a howitzer, take care of the swaybar bushings first.
Old Mar 4, 2004 | 10:48 PM
bakerwt's Avatar
bakerwt
3rd Gear
Default Re: Suspension creaking (Racer1x)
Thanks for the advice. I should be able to get this covered under the extended warantee.
T
Old Mar 4, 2004 | 10:49 PM
bakerwt's Avatar
bakerwt
3rd Gear
Nope.... I'm still runnin ght original suspension
Old Mar 5, 2004 | 03:57 PM
Monster231's Avatar
Monster231
Default Re: Suspension creaking (TGrits10)
Thats why I bought the extended warrenty. It paid its self off ten fold.
Old Mar 5, 2004 | 05:04 PM
LoneStarFRC's Avatar
LoneStarFRC
Anti-roll bar bushing noise, usually the front ones. Remove clamps, apply a little lube and reinstall. Not uncommon.
BTW, new front (and rear) bushings come prelubed from the factory. Those that said something about the front bar "not supposed to be lubed" mis-speaketh. HTH
Robert :)
Old Mar 5, 2004 | 05:38 PM
vectorz's Avatar
vectorz
Default Re: Suspension creaking (LoneStarFRC)
Robert :)
Roll bar?
Old Mar 5, 2004 | 05:40 PM
vectorz's Avatar
vectorz
Y'know, mine started creaking after I lowered mine also. Shooot, I wonder if this is normal.
Old Mar 5, 2004 | 07:54 PM
LoneStarFRC
Default Re: Suspension creaking (vectorz)
Robert :)
Roll bar?
:yesnod: Yes sir. Many people call them (mistakenly) a "sway-bar". They are not. They do not control "sway". That is only a slang term for them. HTH :D
Robert
To Suspension creaking
