Optima Red Top Battery....why do my lights still dim when.....
Old Mar 2, 2004 | 12:21 AM
FLYNAVY30's Avatar
FLYNAVY30
Default Optima Red Top Battery....why do my lights still dim when.....
...I put the windows down???? My stock battery crapped out and left me high and dry over at base today. Decided to skip the jump start process and just got a ride to the local Pep Boys and picked up an Optima Red top. Hooked it up, everything works fine. But my lights till dim when I lower the windows. Is this something I just have to live with?? I thought that would stop when I replaced the battery.
Old Mar 2, 2004 | 03:43 AM
Sorny's Avatar
Sorny
Default Re: Optima Red Top Battery....why do my lights still dim when..... (FLYNAVY30)
:lurk:
I'm curious as well. Perhaps my battery isn't about to die...
Sorny
Old Mar 2, 2004 | 03:48 AM
Richin Chicago's Avatar
Richin Chicago
Just a guess but are you sure the new battery is fully charged? Maybe an overnight charge to be sure.
Old Mar 2, 2004 | 04:04 AM
TGrits10's Avatar
TGrits10
Default Re: Optima Red Top Battery....why do my lights still dim when..... (Richin Chicago)
might be alternator as well. Ever since I've had my car the headlights have dimmed for an instant when my brakelights come on, that sort of thing...I was always :skep: about it, but never had any other ill effects. Then in the process of what turned out to be a bad starter I found out that the alternator was pumping like 77 amps instead of the expected/normal 115 or whatever it was. They quoted me a price to replace the alternator, but I decided it wasn't worth a few hundred bucks to keep the headlights from occasionally dimming, and said teh heck with it.
Old Mar 2, 2004 | 08:58 AM
Sir Sel's Avatar
Sir Sel
Mine does it also, before and after optima yellow top install from day one I purchased it new. :confused:
Old Mar 2, 2004 | 09:19 AM
Lestat52's Avatar
Lestat52
Mine also does that. Bought car new and did it from day 1. I have the red top but it still does it. I just learned to ignore the momentary dimming.
Old Mar 2, 2004 | 09:41 AM
BayouVette's Avatar
BayouVette
Default Re: Optima Red Top Battery....why do my lights still dim when..... (Lestat52)
same here.. just looks like another "normal" problem gm fails to notice... I hope it dont get worse when I install my stereo
Old Mar 2, 2004 | 09:57 AM
FLYNAVY30's Avatar
FLYNAVY30
Default Re: Optima Red Top Battery....why do my lights still dim when..... (BayouVette)
cool....as long as its "normal"
Old Mar 2, 2004 | 10:47 AM
Jeff Jeff's Avatar
Jeff Jeff
I had the same problem with the stock battery, and also with the red top. Not sure if there is any way to fix it.
Old Mar 2, 2004 | 10:48 AM
Fleet 1's Avatar
Fleet 1
Default Re: Optima Red Top Battery....why do my lights still dim when..... (TGrits10)
I have the problem when I step on the brakes the headlites ficker once and I noticed the l.e.d on the radio flickers as well. :crazy:
Old Mar 2, 2004 | 05:35 PM
TLewis4095's Avatar
TLewis4095
Default Re: Optima Red Top Battery....why do my lights still dim when..... (Fleet 1)
Comon problem...I have it as well. Getting worse...I'm sure it is a faulty altenator. Easy swap. :cheers:
Old Mar 2, 2004 | 07:19 PM
Rays Vet's Avatar
Rays Vet
Default Re: Optima Red Top Battery....why do my lights still dim when..... (TLewis4095)
More than likely the alternator. Not that it is defective but not enough amperage to cover the electrical load.GM was right on the edge with this one.
Old Mar 3, 2004 | 01:10 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Optima Red Top Battery....why do my lights still dim when..... (Rays Vet)
It can also be caused by a higher than normal resistance in the wiring from the source (alternator/battery). A little more current draw through the resistor will drop the voltage to the rest of the system and you will get some flickering as the current starts and stops. Check the battery cables for corrosion. They might be slightly undersized also. Since the alternator isn't set up for remote sensing it can't adjust for voltage differences at the end of a long wire.
Bill
Bill
Old Mar 3, 2004 | 01:53 AM
BigBlue's Avatar
BigBlue
Default Re: Optima Red Top Battery....why do my lights still dim when..... (Bill Dearborn)
My truck, my dad's car, and my mom's truck all do it. Done it since new. Everycar we've ever owned has done it. No matter what make or model.
Old Mar 3, 2004 | 01:57 AM
Shylor's Avatar
Shylor
If you engine is running when you do this, then your battery isn't at fault.
Old Mar 3, 2004 | 03:50 AM
lowdowndirty's Avatar
lowdowndirty
:iagree: This is not due to the battery.
Old Mar 3, 2004 | 06:28 AM
Could be your alternator also. If it is not putting out a sufficient charge, the lights will dim. It may dim slightly because you are putting more drain on the system when you use the windows.
Old Mar 3, 2004 | 05:15 PM
wwashing's Avatar
wwashing
Default Re: Optima Red Top Battery....why do my lights still dim when..... (lowdowndirty)
This is normal in all cars. It's not a problem. When a new load is put on the electrical system it take a moment for it to respond to the new demand and compensate with more current.
Don't worry about it. :cheers:
To Optima Red Top Battery....why do my lights still dim when.....
