Just changed my MAF....
Mar 2, 2004 | 04:29 PM
I just remover the POS Granatelli Mass Airflow, and replaced it with my stock one. Do I have to do a relearn or should I just drive it, and let it learn ??? Thanks for any help... :cheers:
Mar 2, 2004 | 04:49 PM
Re: Just changed my MAF.... (Bill Vett)
Just drive it and let it learn, should be ok.
Mar 2, 2004 | 04:57 PM
Re: Just changed my MAF.... (lar66BB)
The Granetelli held my car back for its first year..
Once I went back to stock, I started liking my car again... :yesnod:
Mar 2, 2004 | 05:10 PM
Re: Just changed my MAF.... (YO-EL)
My car didn't feel so hot either, I'll go out tonight or Saturday when I go to Kirban's for a tour. I'll let you know how it feel, thanks El.
Mar 2, 2004 | 06:35 PM
Bill...
I think going back to the stock MAF, (hope you took the screen out too), will really wake your car up, as it did mine 3 years ago...
Another tip since you have just done this....
I'd remove the negative cable from the battery for 5-10 mins to clear out all the learned fuel trims & cells...
This way you're starting fresh.. Your PCM & car will love you for it! :yesnod:
Mar 2, 2004 | 06:52 PM
CA Events Coordinator
a computer relearn would be a fresh start for your car. :yesnod:
VR :cheers:
Mar 2, 2004 | 07:27 PM
:iagree: with the pos part for sure--I went back to stock with good ends and no screen and have had no probs.
Mar 2, 2004 | 09:25 PM
I hear nothing but bad things about Granatelli. I'm stayin' away!
Mar 3, 2004 | 11:57 AM
What effect do you get from removing the screen?
What is the screen's purpose?
Mar 3, 2004 | 12:19 PM
Re: Just changed my MAF.... (billiardcue)
Thanks guys, I did a relearn and it might just be in my head but the car felt stronger and the mpg seems better. I think the screen is to straighten out the air flow. I'm told that if you have an after market intake some say it will help, others have complained of a stall/ stumble or an uneven idle.
Mar 3, 2004 | 12:27 PM
Removing the screen on a stock car will make it run lean. If you do switch your OE MAF that has a screen to a non screen OE or aftermarket unit, (excluding the POS Granatelli MAF) you will need to retune the car.
VR :cheers:
