Z06 Heads / Cam info
Old Mar 2, 2004 | 05:06 PM
RD3721's Avatar
RD3721
Default Z06 Heads / Cam info
Hello,
I have decided not to put a nitrous system on my corvette. If anyone has any info on the stock Z06 heads and cam, I would apprreciate the info. I'm serious thinking about changing my C-5 heads and cam for the stock Z06 heads and cam. I already have the LS6 intake so why not complete it with the Z06 heads and cam? If anyone can help me along with any computer changes needed, I would greatly appreciate it.
Thanks for your time.
Bob :cheers:
[Modified by RD3721, 1:18 AM 3/3/2004]
Old Mar 2, 2004 | 05:50 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Z06 Heads / Cam info (RD3721)
You can get a good deal on a package from GM parts direst and we can do the install or tuning or both.. Let me know if you have any questions.. :seeya :seeya
Old Mar 2, 2004 | 09:01 PM
mdhmi's Avatar
mdhmi
I've looked at this option as well. If you decide to pull the trigger and do the Z06 H/C package please keep us posted on the cost and your feelings of the added performance.
Mark
Old Mar 3, 2004 | 03:17 PM
RD3721's Avatar
RD3721
Default Re: Z06 Heads / Cam info (mdhmi)
Hello Mark,
I'm still kicking this Z06 H/C idea around. If I do go through with it, I wil get back to you and let you know what I think about the change.
Bob :cheers:
Old Mar 3, 2004 | 03:33 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Bob,
I would sure like to know what you decide and how it turns out if you choose to upgrade the heads, cam, etc.
Keep us informed.
:cheers:
Old Mar 3, 2004 | 05:26 PM
billmartin's Avatar
billmartin
Default Re: Z06 Heads / Cam info (REBEL03)
Bob - If you read the thread just above yours about one fellows disaster with an aftermarket head(Patriots) with a car as expensive as a C5, one becomes motivated to stay with factory parts. I have a '03 C5 M6 and am just about out of bolt on options. I want to keep the daily driver smoothness and reliability, but with the extra HP available in that margin between stock and a "noticeably altered" drivetrain. The LS6 heads and GM "hot cam" should be worth some power, without sacrificing driveability. I am sincerely interested to know how your search turns out....
Old Mar 4, 2004 | 11:28 AM
Heretic's Avatar
Heretic
Default Re: Z06 Heads / Cam info (billmartin)
Seems like more folks are coming around to my way of thinking.
I want to drive my car, not wrench on it continously.
Old Mar 4, 2004 | 01:40 PM
JerriVette's Avatar
JerriVette
Default Re: Z06 Heads / Cam info (Heretic)
If your going stock Z06 heads and cam..maybe waiting until the AFR heads hit could be a boon to you.
As there is no core charge I'd imagine 700 to 900 for a set of Z06 heads and cam will be available soon after the Z06 owners start switching over to AFR heads?
just a though.
Old Mar 4, 2004 | 07:48 PM
Greg_E's Avatar
Greg_E
Default Re: Z06 Heads / Cam info (JerriVette)
Why not get the GMPP LS6 cnc'd heads and one of the aftermarket sleeper cams. The heads will only be about $200 more for the pair, than what the stock ones will cost and the cam will be around $200 more than the stock GM LS6 cam. You'll still have good reliability and drivability, with better performance than an LS6 upgrade package. :cheers:
Old Mar 4, 2004 | 07:55 PM
pdd000's Avatar
pdd000
ifu go through all that trouble yr better of to go with a little bigger cam. tr220 or tr224 awesum street cams and very reliable and not huge
[Modified by pdd000, 6:55 PM 3/4/2004]
Old Mar 4, 2004 | 08:03 PM
Greg_E's Avatar
Greg_E
Default Re: Z06 Heads / Cam info (pdd000)
Yep. Those would be good choices. I went with the LPE GT2-3, but that required changing the valve springs. I'm pretty sure you don't need to do that with the TR cams.
To Z06 Heads / Cam info
