Another dreaded torque converter thread
Old Mar 2, 2004 | 07:13 PM
Nightdoc's Avatar
Nightdoc
Default Another dreaded torque converter thread
Can't find the answer to the following question in SEARCH. What is meant when a particular TC is described as loose or tight? :confused:
Old Mar 2, 2004 | 07:27 PM
Mitch C's Avatar
Mitch C
Default Re: Another dreaded torque converter thread (Nightdoc)
A tight converter will feel more like the stock converter. A loose converter will require more throttle imput and RPM to get the car to move off from a stop. Generally speaking a converter with alot of stall 3500+ and a low STR (less than 2.0) will be more loose than a converter with less stall and a high STR (2.0+). :cheers:
[Modified by Mitch C, 6:30 PM 3/2/2004]
Old Mar 3, 2004 | 01:05 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Another dreaded torque converter thread (Mitch C)
Another dreaded torque converter thread !
:yesnod: :yesnod: :yesnod:
:iagree: :iagree:
To Another dreaded torque converter thread
