Stroker motor owners step in...............
Old Mar 5, 2004 | 07:33 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default Stroker motor owners step in...............
If you drive at interstate speeds(70+ :D ) how much oil do you normally burn in say 400 miles?
Old Mar 5, 2004 | 07:40 AM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Re: Stroker motor owners step in............... (ALLTHROTTLE&NOBOTTLE)
Prolly none really..............................mayb e a teaspoon :confused: :seeya You BIG tire **** :D :lol: :p: :jester
[Modified by Buckmaster, 7:58 AM 3/5/2004]
Old Mar 5, 2004 | 07:53 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
I am just breaking in with a heavier oil so I don't know yet but will post when I have a little more time and miles on the motor--
Old Mar 5, 2004 | 08:25 AM
01C5fan's Avatar
01C5fan
None to speak of here either. WOT is where I have the problem.
Old Mar 5, 2004 | 08:45 AM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
Default Re: Stroker motor owners step in............... (01C5fan)
:iagree: And I think the restrictive Manifold is contributing to that :D
Old Mar 5, 2004 | 09:01 AM
vstella's Avatar
vstella
Gee..let me get my calculator and figure that out for you:rolleyes:....
..'jus a little..not worth mentioning really. I use Royal Purple #21 ONLY!
Old Mar 5, 2004 | 09:56 AM
Y2K Z07 MAN's Avatar
Y2K Z07 MAN
Default Re: Stroker motor owners step in............... (vstella)
Ditto, no noticible consumption here either.
427C5R MTI
Only consumption I have is Reptiles and etc !!!!
Old Mar 5, 2004 | 10:37 AM
ZO6Les's Avatar
ZO6Les
I drove to Fla and back, over 1100 miles, averaged 80 MPH, zero oil consumption.
Les
Old Mar 5, 2004 | 10:39 AM
Cruise-In V Veteran
NCM Ambassador
Default Re: Stroker motor owners step in............... (Buckmaster)
You BIG tire ****
:lol:
BFG loves me........... :eek: You too can be a BTMF :yesnod:
Reason I ask is driving to, during and after home from SC I burned 3 quarts of 10W-40. Bear in mind that's over 25 1/4 mile passes and sustained speeds of 75+ for 900+ miles :reddevil with bursts.
Car runs to good to be much of an issue and the plugs look :thumbs: with near 20 mpg. Might do some testing on pressures though.........car has nitrous on it so the rings may be an issue.........about 4K on the motor.
Just wondering.............so you's guys go drive 900 miles & give me a report back :D :cheers:
p.s., Vince, I expect your report to be to the gram :jester were are those videos!
[Modified by ALLTHROTTLE&NOBOTTLE, 10:42 AM 3/5/2004]
Old Mar 5, 2004 | 11:06 AM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
On last years trip to BG (1500 mi. round trip) I used about 1/2 quart. That was with only pass down the 1/4 and some playing around and high speed bursts on the way home.
I would say it's still about the same now.
Old Mar 5, 2004 | 12:17 PM
fast 98 C5's Avatar
fast 98 C5
Default Re: Stroker motor owners step in............... (Flyin'Brian)
None to speak of
Old Mar 5, 2004 | 12:43 PM
vstella's Avatar
vstella
..p.s., Vince, I expect your report to be to the gram :jester were are those videos!... ALLTHROTTLE&NOBOTTLE
It's comin', I'm almost there....You want it right or fast! :lol:
BTW..You have that white coupe ..right? Where's your sig pic :rolleyes: You need to fix that :yesnod:
Old Mar 5, 2004 | 12:56 PM
Cruise-In V Veteran
NCM Ambassador
[QUOTEIt's comin', I'm almost there....You want it right or fast! :lol:
BTW..You have that white coupe ..right? Where's your sig pic :rolleyes: You need to fix that :yesnod: [/QUOTE]
:thumbs: With ya buddy, it always takes time!
Check my sig..........gott'em both in there :cheers:
Well, I gotta leave work now...............80 degrees and a stroker needs to run :D :seeya
To Stroker motor owners step in...............
