Stuck Cluth???
Old Mar 6, 2004 | 01:54 PM
nericreations's Avatar
nericreations
Default Stuck Cluth???
This is the 2nd time in two weeks where my clutch in my stock 2000 c5 (63k mi)has been acting weird, it doesn't fit the description of this thread/tsb: http://forums.corvetteforum.com/zerothread?id=752704 but it may be related...Here what seems to happen, I got in the car this morning pushed the clutch pedal down but the pedal doesn't seem to do anything until the pedal is 3/4 of the way down. The clutch returns all the way to the top after I release it, it just seems the 1st 3/4 of the travel is useless :crazy: . The 1st time this happened I pumped the clutch a few times, then it started operating like usual. Any Ideas? Thanks :cheers:
Double post :crazy: mods can you delete one?
[Modified by nericreations, 12:58 PM 3/6/2004]
Old Mar 6, 2004 | 06:29 PM
01C5fan's Avatar
01C5fan
Default Re: Stuck Cluth??? (nericreations)
Could be air in the hydraulic line, or a bad slave cylinder, or a clutch whose time has come or any combination of the three. If that's the original clutch, it may be time.
Old Mar 6, 2004 | 08:53 PM
gordonb50's Avatar
gordonb50
I agree. I'd start with trying to flush the air.
Old Mar 7, 2004 | 05:17 AM
Sportsdude's Avatar
Sportsdude
:lurk:
Old Mar 8, 2004 | 05:02 PM
nericreations
Default Re: Stuck Cluth??? (gordonb50)
Thanks, Dropped the car at Corvette's of Houston this morning, I'll keep you'll posted.. :cheers:
Old Mar 9, 2004 | 04:14 PM
nericreations
Supposedly the hydrolic's are others are bad in the tranny, I'm going to go aheard and upgrade z06 clucth, is this all I need for upgrade???
GM part#: 12570806
$364 shipped from http://WWW.GMPARTSDIRECT.COM :confused:
Old Mar 9, 2004 | 05:10 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
You need to upgrade to the Z06 slave cyl also, don't have the part # handy. I'm sure someone else on here will have it.
Old Mar 9, 2004 | 05:26 PM
nericreations
Default Re: Stuck Cluth??? (Flyin'Brian)
Thanks found it: 12564455
is the Z06 Actuator Cylinder:12562767 necessary? :confused:
Old Mar 9, 2004 | 09:06 PM
LoneStarFRC's Avatar
LoneStarFRC
Not really necessary, but if you've got some miles on her, I'd go ahead. If you decide not to right now, at least you can replace it later if necessary without dropping tranny or anything. HTH
Robert
To Stuck Cluth???
