Tach Wire for Shift Light
Old Mar 7, 2004 | 11:59 AM
z06mcw's Avatar
z06mcw
3rd Gear
Default Tach Wire for Shift Light
I found the ground and power wires under the passenger side kick board for a shift light installation on my 2001 Z06. Anyone know how to identify the tach wire in this location? I really don't want to go to the pcm or fuse box.
Old Mar 7, 2004 | 12:10 PM
brent02's Avatar
brent02
Default Re: Tach Wire for Shift Light (z06mcw)
I just put in a shift light last weekend and used this post. http://forums.corvetteforum.com/zerothread?id=619162 Gives me a chance to thank Flyin'Brian for a great post :cheers:
[Modified by brent02, 5:12 PM 3/7/2004]
Old Mar 8, 2004 | 01:40 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Default Re: Tach Wire for Shift Light (brent02)
Very cool post!! My previous Mec charged me for install on my shift light and it has never worked. I'll have to get under the dash and hook it up to the right wire.
Thanks,
JB
[Modified by jbsblownc5, 10:41 PM 3/7/2004]
Old Mar 8, 2004 | 01:59 AM
SQEZN BI's Avatar
SQEZN BI
Default Re: Tach Wire for Shift Light (jbsblownc5)
I used brians under dash location which was super easy to locate and tap wire but my shiftlight wouldnt work due to low voltage signal apparently gm uses very low voltages 3 to 5v and my autometer shiftlight could not pick up a signal. This might be your problem when you had it installed whatever type it is. i had to open it up and bypass the 10k resister on the signal wire right were it enters circuit board this was autometers recomendation maybe it will be usefull to you .
Old Mar 8, 2004 | 02:02 AM
blackbelt's Avatar
blackbelt
i've got a raptor shift light and need to install so what do I do once i've located the tach wire. I'm not much of a electronics guy but can get buy if someone explains.
Old Mar 8, 2004 | 07:39 AM
rwj383's Avatar
rwj383
Default Re: Tach Wire for Shift Light (blackbelt)
there are 2 PCMs behind the pass front wheel well panel. Only one of the PCMs have a wire #10. White wire. Splice in there. Good to go.
robert judd
Gen3MS
Old Mar 8, 2004 | 07:58 AM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Tach Wire for Shift Light (rwj383)
robert judd
Gen3MS
Robert, that's the same wire that I found just left of the steering column, much easier than getting to the PCM :yesnod:
[Modified by Flyin'Brian, 7:14 AM 3/8/2004]
Old Mar 8, 2004 | 08:24 AM
dahoof's Avatar
dahoof
Default Re: Tach Wire for Shift Light (Flyin'Brian)
Thanks to Brian, I found the wire in the console under the steering wheel. I have a raptor and it was a breeze to install after the wire was found!!
:thumbs:
[Modified by dahoof, 7:24 AM 3/8/2004]
To Tach Wire for Shift Light
