z51 shocks same as z06?
Old Mar 7, 2004 | 06:30 PM
T_Vert's Avatar
T_Vert
Default z51 shocks same as z06?
i was looking at a shock comparison from a magazine a while ago and both the z51 and z06 had the same thing listed for shocks:
Sachs 45mm gas-charged monotube
in fact the only diff was the rear spring and front sway bar. Am i wrong here?
dave
Old Mar 7, 2004 | 11:00 PM
EBSDallas's Avatar
EBSDallas
Default Re: z51 shocks same as z06? (TT_Vert)
IIRC, the Z06 also has the X brace that's used to stiffen the frame in the convertible.
EBS
Old Mar 7, 2004 | 11:02 PM
T_Vert's Avatar
T_Vert
Default Re: z51 shocks same as z06? (EBSDallas)
huh??
Old Mar 7, 2004 | 11:24 PM
dogdoc97's Avatar
dogdoc97
there was an earlier post about the differences b/w the two; I recall the front sway is different on the Z, and I understand that the shocks ARE diffrent; in fact I read that the 04 shocks are the best yet on the Z, including better than Bilsteins that we all have tried, dogdoc :cheers:
Old Mar 8, 2004 | 12:16 AM
T_Vert's Avatar
T_Vert
Default Re: z51 shocks same as z06? (dogdoc97)
im aware of the spring/swaybar differences. I was wondering primarily about the shocks. Its my understanding that the valving is different but they are identical otherwise, just trying to verify. The 04 z06 shocks are also almost 400 vs. 300 or so for the bilstein sports.
Dave
[Modified by TT_Vert, 11:17 PM 3/7/2004]
Old Mar 8, 2004 | 01:34 AM
411_monkey's Avatar
411_monkey
There was an article before i think that showed that a coupe with Z-51 with supercar tires handled virutally the same as a stock Z06 wasn't there?
Old Mar 8, 2004 | 01:43 AM
allanlaw's Avatar
allanlaw
'04 Z06 shocks are $330 delivered, from more than one Forum vendor. The Bilstein Sports are maybe a bit more when you factor in shipping charges. Regardless of the price, the Z shocks are better IMHO - I've had both on the same car.
Old Mar 8, 2004 | 11:38 AM
T_Vert's Avatar
T_Vert
Default Re: z51 shocks same as z06? (allanlaw)
wow. well the first vendor who can give em to me for 330 has a sale today.
dave
Old Mar 9, 2004 | 12:35 PM
T_Vert's Avatar
T_Vert
can someone tell me what vendor had these for 330? nobody has replied as of yet.
Dave
Old Mar 9, 2004 | 01:10 PM
Richin Chicago's Avatar
Richin Chicago
Dave
Z06 Z18 Z16 Shocks Part#
10339944 Front
10339945 Rear
I think you can get these at http://www.gmpartsdirect.com
for about $340.00 delivered.
Old Mar 9, 2004 | 01:12 PM
Richin Chicago
EBS
Maybe you are thinking about the brace that goes across the back where the coupe is just glass. That's the only extra brace I know of.
Old Mar 9, 2004 | 01:27 PM
T_Vert's Avatar
T_Vert
Default Re: z51 shocks same as z06? (Richin Chicago)
are those definately the 04 z06 shocks?
Dave
Old Mar 9, 2004 | 02:05 PM
Richin Chicago
Dave
http://www.z06vette.com/forums/showt...threadid=44955
Old Mar 9, 2004 | 02:36 PM
StickTail's Avatar
StickTail
Yes they are indeed different.
As with Z51, Sachs shocks are used. Shock valving for Z06 changed in three areas compared to Z51. Damping of low velocity suspension movement typical of body roll was increased at all four corners. At the rear only, high velocity damping was changed, with compression damping actually decreasing (because of the higher spring rate) and rebound damping increasing, to improve wheel control.
To z51 shocks same as z06?
