Hotchkis???
Old Mar 8, 2004 | 02:09 AM
vetteboy_tr's Avatar
vetteboy_tr
Default Hotchkis???
I have a standard suspension setupon my coupe vette.I want to buy Hotchkis sway bar kit to improve the handling and will be hotchkis be effective with standard shocks?or do i need to change the shocks? :party:
Old Mar 8, 2004 | 04:53 AM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Default Re: Hotchkis??? (vetteboy_tr)
You don't need to change your shocks when you install the anti-sway bars. The bars will significantly reduce body roll in turns, but should not increase the harshness of your ride.
If you have the base suspension, it may not be a bad idea to upgrade the shocks at the same time to realize a better overall benefit from the suspension modifications.
Old Mar 8, 2004 | 08:28 AM
Patches's Avatar
Patches
I have F45 with my Hotchkis setup and love it. As a cheaper, but effective, alternative, go with the Z06 setup as it's close to the Hotchkis minus the Heim links. :cheers:
Old Mar 8, 2004 | 09:19 AM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
The Hotchkis swapbars will make a very noticeable difference in your car's handling without having to change the shocks. We have quite a few swaybar packages in stock and are offering discounts to forum members through the weekend. Just call or e-mail for pricing!
Tom
Old Mar 8, 2004 | 10:23 AM
JLinCA's Avatar
JLinCA
Default Re: Hotchkis??? (Patches)
With all due respect Patches you are wrong on this one. My car is has the Z-51 suspension and swapping out the stock bars with the Hotchkis made a huge difference.
Z51 bars may be cheaper, but they don't match the performance of the Hotchkis bars. I guess it comes down to which is more important.
Old Mar 9, 2004 | 12:01 PM
MTV's Avatar
MTV
St. Jude Donor '03-'04-'05
Default Re: Hotchkis??? (JLinNY)
My understanding is Z51 and Z06 have the same Rear Sway Bar. The Z06 is bigger and stiffer in front. Hotchkis is bigger and stiffer (heavier) than Z06 front and rear. So when one upgrades a front Sway from a Z51 to either a Z06 or Hotchkis, there will be a noticeable difference. I'm not sure there's a huge difference in Z06 and Hotchkis that would not ultimately be otherwise affected by shocks, springs and most significantly, Tires . Best,
mtv :thumbs:
To Hotchkis???
