Idle??
Old Mar 8, 2004 | 01:50 PM
-Blue Vette-'s Avatar
-Blue Vette-
Default Idle??
Why are the vettes set to idle at 800 rpms versus the SS and WS6 which are set at 500 rpms at idle?
Old Mar 8, 2004 | 04:11 PM
chaase's Avatar
chaase
St. Jude Donor '12
Default Re: Idle?? (-Blue Vette-)
Mine idles around 500rpm?
Old Mar 8, 2004 | 04:42 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Stock 2000 idle is at 725
Old Mar 8, 2004 | 05:39 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Re: Idle?? (Flyin'Brian)
________________________________________ ________________________
My stock 98 idle is around 750 rpm, maybe a little lower...maybe a little higher
Old Mar 8, 2004 | 07:06 PM
Flyin'Brian
Cruise-In I Veteran
Default Re: Idle?? (vette#one)
Probably 725 also. mine is from the program LS1 Edit. so that is exacly what it is :yesnod:
Old Mar 8, 2004 | 07:23 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
F-bodies are not fly-by-wire... Vettes are.
Our idle is a target value in the look up table. The PCM uses IAC values/steps and the timing tables, along with the target idle RPM, to determine final RPM.
A little more complicated for idle while moving.
FWIW.
joel
Old Mar 9, 2004 | 02:04 PM
-Blue Vette-
Default Re: Idle?? (Bink)
Just needed to make sure the idle was proper... :thumbs:
To Idle??
