Sluggish gas guage
Old Mar 9, 2004 | 08:37 AM
Ron Cleaver's Avatar
Ron Cleaver
Default Sluggish gas guage
I've read posts about gas guages showing the wrong level. But the behavior of my gas gauge on my 2000 C5 is different. It takes about 5 minutes to reach the correct level. Anyone had a similar experience?
BTW the manual says don't add additives to the gas tank, but I seem to remember some adding a Chevron product.
Old Mar 9, 2004 | 09:06 AM
fast2000vette's Avatar
fast2000vette
Default Re: Sluggish gas guage (Ron Cleaver)
I used a fuel system cleaner to fix mine. Might want to try that. :seeya
Old Mar 9, 2004 | 12:29 PM
silverminevette's Avatar
silverminevette
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '03-'04-'05-'06
It takes about 5 minutes to reach the correct level. Anyone had a similar experience? BTW the manual says don't add additives to the gas tank, but I seem to remember some adding a Chevron product.
I noticed something similar the last time I filled up. When I first started her up the gauge registered 3/4 full. Took the 5 mile ride home to finally register full. I had just used Techron additive to try to avoid the fuel sensor problems I've read about here. This was the next fill-up after that. :confused: Maybe someone else will know what's up! :steering:
Old Mar 9, 2004 | 02:24 PM
JasonFRC's Avatar
JasonFRC
Default Re: Sluggish gas guage (98silvermine)
I'm a bit intrigued by this. Can you elaborate? Or point me to a link explaining this issue?
How does a fuel system cleaner help a fuel gauge problem? Is there a sensor that gets dirty?
:confused:
Old Mar 9, 2004 | 03:13 PM
silverminevette
Cruise-In V Veteran
Default Re: Sluggish gas guage (JasonFRC)
Interesting link - http://forums.corvetteforum.com/zerothread?id=514935
Old Mar 9, 2004 | 09:20 PM
ljkuntz's Avatar
ljkuntz
had a similar problem with my 1998 used redline fuel treatment and has been good for two years now hope this helps :flag
Old Mar 9, 2004 | 10:44 PM
RedC5's Avatar
RedC5
Default Re: Sluggish gas guage (ljkuntz)
Mine just did it this week...1/2 tank slowly to full. Do not overfill when filling. When pump stops, do not add any more. I did on this fill-up by mistake. My '98 only does this in winter sometimes.
Old Mar 9, 2004 | 10:59 PM
JasonFRC's Avatar
JasonFRC
Default Re: Sluggish gas guage (RedC5)
Excellent! Thanks for the information.
I love learning new stuff about my car.
I ran out of gas a couple weeks ago in my newly acquired FRC. :)
It still read 1/4 tank. That's embarassing. Pushing my beautiful new sports car out of a bust intersection.
I'll give a fuel system cleaner a try. My favorite is BG's 44K.
I bookmarked the TSB link. I hope I don't have to do it! :yesnod:
Old Mar 10, 2004 | 06:07 AM
Ron Cleaver
I thought perhaps it was the Shell gas I've been using. So last Saturday I filled up with Exxon. Already the gauge seems better. Now it's only taking about a minute or two to reach the correct level. If it keeps getting better, I'll continue using Exxon.
Old Mar 10, 2004 | 09:49 AM
leaftye's Avatar
leaftye
And I thought it was the tank pressurizing itself. It doesn't bother me though, I like getting more gas the more I drive!
Old Mar 10, 2004 | 10:54 AM
Ron Cleaver
Default Re: Sluggish gas guage (leaftye)
The potential problem is that the gauge may not be registering correctly. So you could run out of gas. I doubt you want that to happen. :nono:
Old Mar 10, 2004 | 03:46 PM
leaftye's Avatar
leaftye
My gas gauge is pretty accurate once it gets up there. I've run my tank down to within half a gallon a couple of times, and the DIC & gas gauge didn't let me down.
Old Mar 11, 2004 | 06:36 AM
Ron Cleaver
Then you should read some other posts from guys who have run out of gas when they thought the gauge was OK. I've been monitoring the accuracy of my gauge when I get gas and it seems OK too, but I still wonder if it will stay that way.
To Sluggish gas guage
