leaky diff and gear and convertor decisions....
Old Mar 9, 2004 | 10:05 PM
CrazyMagMan's Avatar
CrazyMagMan
St. Jude Donor '05
Default leaky diff and gear and convertor decisions....
Well, I've had a leaky rear diff for awhile now and when I checked under the car this weekend I found that the right hand side had started leaking also at the halfshaft, so decided its time she sits until I get a new diff and torque convertor. I've pretty much decided on 3.42s and the PT2400 as I will be doing some mountainous backroad carving, interstate driving, and maybe some autocrossing. Ooooh, but I'd love to have 3.73s, but I'm not sure as Maggie is an A4 with TTS longtubes and Borlas. Just not sure I could bear it on the interstate...... What do you think? 3.42s or 3.73s?
Old Mar 9, 2004 | 10:07 PM
IMQUIK's Avatar
IMQUIK
Default Re: leaky diff and gear and convertor decisions.... (CrazyMagMan)
3.73's & SS-3600!! :D
Old Mar 9, 2004 | 10:10 PM
Mike Mercury's Avatar
Mike Mercury
3.42 if you stay with EMT run-flats; 3.73 if you throw away the run-craps.
Old Mar 9, 2004 | 10:12 PM
CrazyMagMan
St. Jude Donor '05
Default Re: leaky diff and gear and convertor decisions.... (Mike Mercury)
Awww, I have Kuhmo Ecsta MX's. Oooh, I love those tires so much!!
Old Mar 10, 2004 | 07:31 AM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
Mike,
You probably want to stay with the 3.42 rear end as you mentioned the mountain driving. A 3.73 rear with matching converter may not be too fun in a lot of twisties. I opted for a little more stall with my converter selection (Vig 2800), but mostly to get a little more performance at the drag strip while maintaining street manners. One more thing to consider is adding a tranny cooler as you are going with a higher stall converter. Heat kills transmissions.
:cheers:
Old Mar 10, 2004 | 09:13 AM
TXSTICK's Avatar
TXSTICK
Default Re: leaky diff and gear and convertor decisions.... (bgood)
Do the 3.73s and don't look back. You will love them since you have better tires already. :thumbs:
Old Mar 10, 2004 | 11:05 AM
Mike Mercury
Default Re: leaky diff and gear and convertor decisions.... (TXSTICK)
Do the 3.73s ... since you have better tires already.
:iagree:
Old Mar 10, 2004 | 05:43 PM
yankeevetteconvert's Avatar
yankeevetteconvert
:iagree:
Me too!
Old Mar 10, 2004 | 08:30 PM
CrazyMagMan
St. Jude Donor '05
Default Re: leaky diff and gear and convertor decisions.... (yankeevetteconvert)
hmmmm.........
To leaky diff and gear and convertor decisions....
