May be a stupid brake question...
Old Mar 9, 2004 | 10:49 PM
magnetized's Avatar
magnetized
St. Jude Donor '09
Default May be a stupid brake question...
...I just got the pads replaced on all 4 wheels and have a new brake squeal. It didn't do this with worn out pads. :skep: It occurs with light pressure on the brake pedal. Is this just the new pads wearing in or is it another, new problem? The car stops like it did when it was new :smash:
:steering: Ride On :seeya
Old Mar 10, 2004 | 10:20 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: May be a stupid brake question... (magnetized)
it could be the backing plates of the pads rubbing the steel caliper piston... they sell a compound that absorbs this metal to metal contact.. or it couls be
the metalic in the pads is harder than the rotors.. this will cause irrepairable damage to the rotors... Many guys on this forum have complaned about Hawk pads causing sqeeking at light stopping pressure...I had hawk pads on for a few days... took them off and the noise went away...
Old Mar 10, 2004 | 10:26 AM
leaftye's Avatar
leaftye
Default Re: May be a stupid brake question... (Evil-Twin)
Squeeling is also a sign of great brakes. It's a side-effect of all the extra friction between the pad and rotor. Quiet brakes have less friction, and slide over the rotor more easily, diminishing the braking capacity. I would rather have kickbutt brakes that squeel and avoid a crash because I won't be grateful for having brakes that remained silent just before I rear ended someone.
Old Mar 10, 2004 | 11:39 AM
THENAKEDi's Avatar
THENAKEDi
Default Re: May be a stupid brake question... (leaftye)
Sounds like some excuse they tell hodads at the Audi dealership...
Old Mar 10, 2004 | 11:51 AM
Evil-Twin's Avatar
Evil-Twin
You dont have a clue about brakes.... squeal is caused by metal to metal contact... Ive been an automotive engineer for GM for 35 years... squeal is the sign there is something wrong... To the original poster... There are many opinions on this forum... rather than listening to opinions.. try to find some people on this forum who are professionals in the field.. there are many here... many professional tuners, racers, engineers, and automotive experts, unfortunatley there are many more wannabees, I've seen many of these wannabees cause consideral damage and expense to new member of this forum. So be careful who you listen too. Welcome to the forum
Old Mar 10, 2004 | 03:53 PM
OldSStroker's Avatar
OldSStroker
I agree with your assessment of some posters. There is a lot of mis-information thrown out as gospel. Some forums are worse than others in this respect. Unfortunately we all don't have out CV in our siggy. About 35 years ago I was doing what EvilTwin does with the "company". We're both Old Farts, I guess. A lot of things have changed, but many haven't. One test drive is worth a 1000 posts, IMO.
If you were near me I'd gladly ride with you and give you my opinion. I'll bet the Evil one would do the same.
Sometimes defining "squeal" is in the ear of the beholder. True metal-to-metal (steel to cast iron) sound is, as you said, big time bad.
There is a chance the sound, at light pedal, is because the pads haven't become intimately acquainted with the rotors yet. IOW, it may not be metal-to-metal contact.
Magnetized, did you burnish the new pads with moderate stops as recommended by many pad manufacturers? Were the pads chamfered on their leading edges? What kind/brand/style of pads? I use Performance Friction Carbon Metallic and burnish them like they say and there's never any "squeal". Are you gettng any new scratches on the rotors? Check outside and inside. One more off-the-wall thought: the worn pad indicator tabs aren't bent too far toward the rotors are they, maybe just on one pad?
My $.02
Old Mar 10, 2004 | 04:05 PM
Richin Chicago's Avatar
Richin Chicago
WOW!
Squealing is a sign of vibration in the human hearing range. Great brakes need not squeal.
Old Mar 10, 2004 | 09:44 PM
zexnitro99's Avatar
zexnitro99
look like you just got a bounus with yours new brakes!
:cheers:
Old Mar 10, 2004 | 10:14 PM
leaftye's Avatar
leaftye
For a pro, you've done little to help him cure his brakes that you soo strongly stated have a problem. While my decision to use the word "squeal" was wrong, there's no doubt that a high friction pad that produces enough force to create tons of braking power and a lot of brake dust is going to make more noise than a gentler pad. That noise may not be what you call squealing, and the good and bad noise are at different frequencies, but both sound like a squeal to me. You may call me a wannabe, even though I have wrenched every car (7 of them) and two motorcycles that I've had, and I've only had 7 years to do it in. Do I make mistakes? Yeah, occasionally I do, I'll admit that. At least I'll admit that, and I learn from them. I take my lessons and try to help other people, instead of flaming people. Flaming is something I'd expect from a teenager or a troll, but definitely not a professional. If you are a professional, you should act like it and help. You can use the guy that posted right after you as an example.
magnetized's Avatar
magnetized
St. Jude Donor '09
Default Re: May be a stupid brake question... (OldSStroker)
I have been relatively easy on the brakes, though last night I did use a good bit of pressure to test the sqealing - not a panic stop but a decent one (the noise was absent.) I was unable to get any specs from anyone who knew jack when I picked up the car (at the dealership :cry and the "vette expert" was gone for the day :( ). As far as I know the brakes would've been the same brand that was on the car previously, but I will find out :smash: I will check the rotors out tomorrow in the light as well :cheers:
Old Mar 11, 2004 | 07:09 AM
stevenll's Avatar
stevenll
Here's some recommended break-in instructions for new pads.
Brake Pad Break-in Procedure courtesy of StopTech
There is only one way to prevent this sort of thing - following proper break in procedures for both pad and disc and use the correct pad for your driving style and conditions. All high performance after market discs and pads should come with both installation and break in instructions. The procedures are very similar between manufacturers. With respect to the pads, the bonding resins must be burned off relatively slowly to avoid both fade and uneven deposits. The procedure is several stops of increasing severity with a brief cooling period between them. After the last stop, the system should be allowed to cool to ambient temperature. Typically, a series of ten increasingly hard stops from 60mph to 5 mph with normal acceleration in between should get the job done for a high performance street pad. During pad or disc break-in, do not come to a complete stop, so plan where and when you do this procedure with care and concern for yourself and the safety of others. If you come to a complete stop before the break-in process is completed there is the chance for non-uniform pad material transfer or pad imprinting to take place and the results will be what the whole process is trying to avoid.
Old Mar 11, 2004 | 08:11 AM
Evil-Twin's Avatar
Evil-Twin
When it comes to brakes.. I could care less about your ego or feelings.. Im concerned only about the safety of the original poster... C5's have a very good brake system... well above average for a street car... and with active handling .. the car is a very stable platform... if the brakes are making noise... there is something wrong.. and Ill flame anyone who could potentially deminish the safety of their brakes and just blow it off as being a good thing... AS far as helping him I pointed to two things it could possibly be,.,but the most important thing I said was there is something wrong... So not only don't you have a clue, but you can't read either....
Old Mar 11, 2004 | 10:22 AM
wrustywrench's Avatar
wrustywrench
easy,, guys,, I have had squeal on new nrakes, break them in correctly, dont stop and let hot brakes set,, drive and cool slowly ,,the break in procedure posted above is correct......the squeal is most likely vibration inducted, not metal to metal, if it goes away under moderate braking,,its most likely not a big deal, as worn/bad pads will grind and you will know it,,,,lets not get pissy about who is right and who is wrong,,,,i really doubt is there is anyting seriously wrong,,but I would check, as I have installed many high performance brakes on street rod and some do squeal at fairground cruising speeds..but not under street braking, baer, wildwood, have both done this. AND there was not a thing wrong. I have seen guys spray tires with tires foam,, in my opinion this is a bad practice,, you spray silicone onto the rotors,,this stuff will play havoc with rotor surface...I have been informed at many trade/professional show (PRI) to wipe tire dressinf on,, or spray as to not get on rotors....just something else hink about...
Old Mar 11, 2004 | 07:30 PM
magnetized's Avatar
magnetized
St. Jude Donor '09
Well, went back to the dealer, had the vette guy duplicate it, and it isn't a big deal. He pulled both rotors and we inspected for any anomalies (none) and it turns out the rear pads are still a bit wavy (haven't been worn in yet.) He cross-sanded the rear rotors a tiny bit to help them speed up the break-in, and the insuing drive had quelled 50% of the noise. His advice was to brake a bit more aggressively and they should be fine. With 20+ years as a vette specialist I believe him. So, tomorrow I'm back to class in Baton Rouge, and those puppies will be put to the test :smash: (traffic :mad)
Thanks to the useful replies, and at least Bill has been able to make a new friend :jester
To May be a stupid brake question...
