Hi-amp alternator required?
Old Mar 9, 2004 | 11:55 PM
Rob Razor's Avatar
Rob Razor
Default Hi-amp alternator required?
Just installed Rockford Fosgate subwoofer, 1200w amp RF w/capacitor, and RedTop Optima battery.
Now lights dim on hard subwoofer hits and amp shut down after 30-minutes. Anyone installed a high amp alternator to deal with simliar issues? If so, where did you buy it, how much, and was it a direct swap?
Old Mar 10, 2004 | 08:49 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Hi-amp alternator required? (Rob Razor)
Myself and quite a few others run high output alternators. Mines a 200amp single wire unit. Most others run a dual regulator 150-200 amp units. The only downside to the single wire is the need to disable the "charge system fault" alarm with ls1 edit, or so I've been told. Otherwise with the single or dual regulator setups, it's just a bolt on, plug in and done setup. :cheers:
Old Mar 10, 2004 | 09:08 AM
Pewter1's Avatar
Pewter1
Default Re: Hi-amp alternator required? (JoeyG)
Where did you purchase and how much?
Old Mar 10, 2004 | 10:41 AM
C5 Curmudgeon's Avatar
C5 Curmudgeon
Default Re: Hi-amp alternator required? (Pewter1)
:iagree: :D
Old Mar 10, 2004 | 11:05 AM
JoeyG's Avatar
JoeyG
Default Re: Hi-amp alternator required? (eddiep)
Bought mine about 5 years ago froma streetwires vendor. BrianW21 bought a externally regulated unit, that looked good from the pics for alot less than I orignally paid. Try a search in the audio/electronics and you'll get some vendor #'s
To Hi-amp alternator required?
