Problem on telescopic Steering wheel
Old Mar 11, 2004 | 09:31 PM
love2dye4u's Avatar
love2dye4u
Default Problem on telescopic Steering wheel
I have set the memory no.1 for my setup. When I start my c5 the steering wheel should pop out to my set up & the seat should move to my setting. And when I exit, it should they should go back to the original positions. Sometime it works, and other times it does not work. When it does not work I have to press the memory no. 1 to work it. It should automatically work every time. Does anyone have an idea what is causing the problem? Please let me know. And my friend has another c5 and his car has the same problem.
Old Mar 11, 2004 | 09:49 PM
jojog's Avatar
jojog
Default Re: Problem on telescopic Steering wheel (love2dye4u)
I am pretty sure you have to pull the key and go through the lock/unlock sequence for memory to work. If you just turn it off and restart or pull the key without locking it and unlocking it - no go on memory! :thumbs:
Old Mar 11, 2004 | 09:51 PM
jojog's Avatar
jojog
Just realized you didn't mention the easy entry/exit feature. If you don't enable it through the options function - it won't go to the easy out position.
Old Mar 11, 2004 | 11:20 PM
SFVetteman's Avatar
SFVetteman
It may be just a glitch that you have to live with. At least that is what I do.
Most of the time my car remembers the settings but sometimes it does not. Most of the time it remembers to do the easy entry thing but sometimes it does not. Most of the time my cruse control works but sometimes it does not. Most of the time my gas gauge works but somtimes it does not. Most of the time my left headlight pops up when I turn on the lights but somtimes it does not :rolleyes:
Old Mar 11, 2004 | 11:43 PM
Mel 2001's Avatar
Mel 2001
Default Re: Problem on telescopic Steering wheel (SFVetteman)
Can you say extended warrant :yesnod:
Old Mar 12, 2004 | 04:14 PM
SFVetteman's Avatar
SFVetteman
Default Re: Problem on telescopic Steering wheel (Mel 2001)
The problem with things that work most of the time is that they always seem to work when you take it to the dealer.
Old Mar 12, 2004 | 08:50 PM
love2dye4u's Avatar
love2dye4u
Default Re: Problem on telescopic Steering wheel (jojog)
Thanks, Jojog.
To Problem on telescopic Steering wheel
