what are the widest front tires
Old Mar 13, 2004 | 11:17 AM
esram's Avatar
esram
Default what are the widest front tires
what are the widest front tires that I can run and not have any clearance issue's. Rims are 18x10
Old Mar 13, 2004 | 11:26 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: what are the widest front tires (esram)
I would suggest a 285/30/18.
It's a short tire, should be no clearance issues. I can't say for sure they wouldn't rub on the inside, that would depend a lot on the wheel offset/backspacing, but people have used this size on 18x10's on the front without problems.
:cheers:
Old Mar 13, 2004 | 03:36 PM
alanh's Avatar
alanh
I totally depends on the structure (shape) of the tire. A good example is the stock Good Year runflat that has a wide tread and square shoulders. The same size Firestone runflat has a narrower tread and rounder shoulders so it has greater clearance in the same wheelwell than the Good Year has. Every tire manufacturer has a slightly different shape to their tire and while the specified size on the tire may be the same, the actual outside dimension and shape of the tire may vary. If you are working with very close tolerances, trial and error is the only way to find out which tire fits and which doesn't. :banghead:
Old Mar 13, 2004 | 06:12 PM
bigDvette's Avatar
bigDvette
Default Re: what are the widest front tires (alanh)
Not your wheel, but I run a 315/35 in teh front. The wheels have to have the right backspacing
Old Mar 13, 2004 | 09:33 PM
blackjack's Avatar
blackjack
Default Re: what are the widest front tires (bigDvette)
285x30x18.
To what are the widest front tires
