Re: How to know when to replace the brake pads (Mac78and2K)
Do the C5s come with the brake warning sensor on the pads that give a "squeeling" sound when the pads are low?
I have helped install quite a few different pad brands and haven't seen one type of pads without the "screech" clips. They should give you plenty of warning.
Because the clips are on the trailing edge of the pad you usually get the first sounds while backing up.
From: Buy USA products! Check the label! Employ Americans
Re: How to know when to replace the brake pads (Richin Chicago)
I bought OEM pads for my Dodge dually when I got hope no squeakers :cuss I bought the premium one too.
