Oil question
Old Mar 14, 2004 | 08:32 AM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Default Oil question
I haven't noticed any oil consumption problems in my 99 before. I took it to the strip last week, and had checked the oil a couple of days before going. It was in the middle of the operating range. After the strip, it's just below the operating range. Is that much consumption normal? I made about 10 runs.
Old Mar 14, 2004 | 01:39 PM
2001 Red Coupe Bandit's Avatar
Default Re: Oil question (mebrahimi)
I had some oil burning problems that hopefully were fixed with upgrading to metal valve seals. I filled it to full, drove 350 miles round trip and ran 10 hard 11 second runs, plus I have a 4000 stall converter and 3.42's so it runs a little higher RPM's any way.
After the strip and drive home I was approx. down 1/2 way between full and add on the dipstick, actually a little higher than 1/2 way between those points.
I think it is normal to burn oil after driving your car hard like that, but I would do what I am doing, just monitor your oil to see if that trend continues, or levels of with normal driving.
The Bandit..................
Old Mar 14, 2004 | 05:27 PM
99C5Vert's Avatar
99C5Vert
Default Re: Oil question (2001 Red Coupe Bandit)
Thanks for the response. I'll keep an eye on it. I doesn't bother me if the oil burning is only due to the runs.
To Oil question
