3:90 gears install will it require LS1-edit
Old Mar 17, 2004 | 10:59 AM
C5 CU's Avatar
C5 CU
Default 3:90 gears install will it require LS1-edit
thinking of installing 3:90 gears in a ZO6...will the pcm need any editing (LS1-edit) or is the speedometer not effected??? any other adjustments?
Old Mar 17, 2004 | 11:23 AM
dahoof's Avatar
dahoof
Default Re: 3:90 gears install will it require LS1-edit (C5 CU)
Only if you hav an auto. You do not need to with a 6 speed. :cheers:
Old Mar 17, 2004 | 11:26 AM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Only to correct your speedometer. You want to buy a whining set of 3.90's?? :jester
Old Mar 17, 2004 | 12:42 PM
The One's Avatar
The One
Default Re: 3:90 gears install will it require LS1-edit (dahoof)
:iagree: :D
Old Mar 17, 2004 | 12:44 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: 3:90 gears install will it require LS1-edit (The One)
:nono:
the reluctor wheel "teeth" count does not change
Old Mar 17, 2004 | 01:41 PM
ArKay99's Avatar
ArKay99
Default Re: 3:90 gears install will it require LS1-edit (Mike Mercury)
:nono:
:iagree: with Mike.
Z06 = M12 transmission. No PCM editing is required. The PCM uses speed sensors on the axles, not the driveshaft. That's pretty :cool:
Old Mar 17, 2004 | 08:55 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: 3:90 gears install will it require LS1-edit (ArKay99)
:nono:
:iagree: with Mike.
:iagree: :cool: :cool:
To 3:90 gears install will it require LS1-edit
