Tire sensor and rims question........
Old Mar 17, 2004 | 06:43 PM
3318C5's Avatar
3318C5
Default Tire sensor and rims question........
I am cosidering getting aftermarket rims for my C5. If I get wheels that are not made to handle the factory air sensors what are my options?? Do I have to reprogram the computer, will the car run correct??? Advise please!!!!!!!! Thanks............ :steering:
Old Mar 17, 2004 | 07:01 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Tire sensor and rims question........ (3318C5)
You can mount a sensor in ANY wheel.
Mine are epoxied and clamped inside the wheels. Has worked fine for 12k miles so far.
If you choose to not run the sensors, you will only get a "service tire mon system" warning at startup. You can press reset and continue on as normal. It does not affect the car's operation at all. If you have a 2000 or earlier, you will have to live with this warning message everytime you start the car if you don't have sensors.
If you have a 2001 or newer car, the TPM system can be "turned off" with a GM Tech-2 programmer. A dealer should have this tool, and you'd have to get them to do it.
:cheers:
Old Mar 17, 2004 | 11:28 PM
98ISGR8's Avatar
98ISGR8
Default Re: Tire sensor and rims question........ (Y2Kvert4me)
does anyone know the part number of the sensor for a 98? Also wouldn't you get a message that the pressure is at zero and the car will be running in maximum speede limit of 55mph? My left front one is bad,takes to long to send the pressure and the car thinks its at zero and considers it a flat.
Old Mar 17, 2004 | 11:36 PM
jmzvet's Avatar
jmzvet
Default Re: Tire sensor and rims question........ (98ISGR8)
I don't have sensors and the pressure reads XXX. It will run WAY over 55!
Old Mar 18, 2004 | 06:09 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Your speed isn't limited, it only tells you not to exceed 55 mph. You can still go as fast as you please.
The sensor part # for a 98 is 10438853
:cheers:
Old Mar 18, 2004 | 12:05 PM
3318C5's Avatar
3318C5
Thanks a lot for the info!!!!!!!!!!! :hurray:
Old Mar 18, 2004 | 12:15 PM
00TORCHCOUPE's Avatar
00TORCHCOUPE
There was a post here just a few days ago from a company that refurbished the sensors pretty cheap. Do a search. :thumbs:
Old Mar 18, 2004 | 10:12 PM
Lawmagnet's Avatar
Lawmagnet
Default Re: Tire sensor and rims question........ (00TORCHCOUPE)
I used 1500PSI epoxy for my sensors...no problems at all.
Old Mar 18, 2004 | 11:01 PM
blackjack's Avatar
blackjack
On my Ccw's I just grind a portion of the sensor off. It looks like it's made of epoxy. and fit it to the wheel with no problems...
To Tire sensor and rims question........
