gm hot cam
Old Mar 18, 2004 | 09:43 AM
jimmagrdII's Avatar
jimmagrdII
Default gm hot cam
can the gm hot cam be used with a magnusun s/c kit on a 2001 m6 coupe? :confused: thanks :cheers:
Old Mar 18, 2004 | 11:49 AM
HITMAN99's Avatar
HITMAN99
Default Re: gm hot cam (jimmagrdII)
I would not use that cam. Blowers typically like a wider lobe separation angle (LSA) and the Hot Cam is only a 112. You should stick with a split-duration, with longer duration on the exhaust side. The blower helps push more A/F into the combustion chamber, & you need more exhaust duration to get the exhaust gases out.
Old Mar 18, 2004 | 10:33 PM
camiv's Avatar
camiv
I am by no means an expert but the place for a GM Hotcam is the garbage! If you are going to do the work yourself or spend money on labor......there are an infinite number of cams that will give you better performance for your investment of time or money. By no means am I trying to slam GM or their cam....just too many cams out there with better performance in my opinion! :troll
To gm hot cam
