Seating New Brake Pads..................
Old Mar 18, 2004 | 08:22 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Seating New Brake Pads..................
Getting ready to install some new rotors from Sport Brakes along with some new ceramic pads. What's the proper way to set the pads???
Old Mar 18, 2004 | 09:29 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: Seating New Brake Pads.................. (Mag Red Monster)
Make sure to use the proper brake pad lubricant (it's metallic.)
Once you have everything back together, make at least 20 stops from 30 MPH using medium to firm pedal pressure before you stop from any higher speeds. Do not overheat the brakes! Once this is done, you can drive normally but no high-speed stops to zero for the first couple hundred miles.
[Modified by Scissors, 9:32 PM 3/18/2004]
Old Mar 18, 2004 | 09:31 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: Seating New Brake Pads.................. (Scissors)
I followed the seasoning instructions on Baer's website and have had no problems.
Old Mar 18, 2004 | 09:54 PM
Mag Red Monster
Elite Member
Default Re: Seating New Brake Pads.................. (Fastguy)
:cheers: Thanks......I'll also check out Baer's site :thumbs:
Old Mar 19, 2004 | 10:59 AM
stevenll's Avatar
stevenll
Here are some instructions I got from StopTech
Brake Pad Break-in Procedure courtesy of StopTech
There is only one way to prevent this sort of thing - following proper break in procedures for both pad and disc and use the correct pad for your driving style and conditions. All high performance after market discs and pads should come with both installation and break in instructions. The procedures are very similar between manufacturers. With respect to the pads, the bonding resins must be burned off relatively slowly to avoid both fade and uneven deposits. The procedure is several stops of increasing severity with a brief cooling period between them. After the last stop, the system should be allowed to cool to ambient temperature. Typically, a series of ten increasingly hard stops from 60mph to 5 mph with normal acceleration in between should get the job done for a high performance street pad. During pad or disc break-in, do not come to a complete stop, so plan where and when you do this procedure with care and concern for yourself and the safety of others. If you come to a complete stop before the break-in process is completed there is the chance for non-uniform pad material transfer or pad imprinting to take place and the results will be what the whole process is trying to avoid.
Old Mar 19, 2004 | 11:05 AM
Patches's Avatar
Patches
Same here. I adhered strictly to Baer's procedures and my setup has performed perfect with no hint of a squeek or pulse. Very smooth and quiet.
According to another guide I read, new rotors should turn a bluish-purple color when seasoned properly. That's the color mine turned after the last round of high-speed stops. The color goes away after a few stops then next time the car is driven.
Old Mar 19, 2004 | 12:40 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
This is the second or third post Ive seen from you that is totally incorrect... I dont know where you get your information, but you obviouly are making it up... Mostly everyone here uses Baer's brake in procedure, which includes some very high speed braking...You post things with bold script... like you are an authority on seasoning.. PLease be sure of your suggestions... especially when it comes to safety issues like brakes and rotors, are correct...
To Seating New Brake Pads..................
