Consensus on Ceramic Coating Stainless Steel Headers?
When I installed my Stainlessworks LTs I did so without removing the sparkplugs..during the process I cracked #3 plug...when I went for drive my car was backfirine under WOT, went back got the Tech II, took some scans while driving and BINGO...#3 bank. I popped the hood and proceeded in starting to remove the plug......now here is where I get to the 70%. When I stuck my hand down to pull the Spark Plug Wire off, there was no warning from radiating heat off the headers, I had been driving the car around for at least 20 mins on a summer day and it only took me 5 mins to pop the hood and get a spark plug wrench. So when I reached down and began pulling the plug off, my index finger leaned on the tube...and my finger instantly scorched turning the whole outside layer a charred white color...it did not even blister for 1 hour because it seared the top layer of skin so fast. So I have to say that within inches the headers with the swaintech coating only felt warm..when they were actually red hot! I guess there is a reason they used it on the space shuttle.
May be over kill but the socks cost 39.99, and the heatshield did decrease the in the car noise level and help keep the foot wells cool.
In my old C4 my right leg would lay against that inner wall and it would get hot.
Anyway The stainless the Slp are made of is the t404???and it has a high ferric concentration I was told and thats why they are coated. apparently there are different grades of SS. The one without any ferrous materials would technically not need coating to prevent rusting. Then its just an issue of heat protection.
I may be wrong, but hey I may be right, or I may be crazy :cheers:
I have my Kooks on order from TSP, with ceramic coating.
