Where oh where is this wire?
Old Mar 19, 2004 | 12:40 AM
brianw21's Avatar
brianw21
Default Where oh where is this wire?
The wideband install manual says to connect the rpm pickup as follows:
"...connect the exposed input lead to to the switch (non power) side of the ignition coil, using supplied Tap"
Any ideas as to what wire and where this might be?
Brian
Old Mar 19, 2004 | 01:10 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Where oh where is this wire? (brianw21)
99 - 01 models, find the white wire, pin # 10, of the red connector.
this is the tach wire. I just installed my wideband.
Old Mar 19, 2004 | 10:26 AM
brianw21's Avatar
brianw21
Default Re: Where oh where is this wire? (ICULUKN-C5)
I didn't know if it would work off the tach wire since the instructions point towards the coil....
This pin,wire,connector... this the BCM at the passenger floorboard, or the ecu?
Also, have you been able to log and verify the RPM?
Brian
To Where oh where is this wire?
