Removed Cats...LOST TORQUE???????
Old Mar 19, 2004 | 10:53 AM
Red5's Avatar
Red5
Default Removed Cats...LOST TORQUE???????
Removed the cats and went with O2 simms. And although I didn't dyno I could swear from SOTP that the car feels slower.
I think I may be able to live with the louder sound. And I don't get the "Smell" I was warned about. But the car feels like it has less out of the hole.
Any ideas what this is about?
Has the car not adjusted itself yet? Will it fix itself?
Does the car require more back pressure in order to build torque?
Any ideas?
Old Mar 19, 2004 | 10:59 AM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Removed Cats...LOST TORQUE??????? (Red5)
This can be a common issue with removing the cats. It directly affects back pressure. Are you running any type of programing ? You might want to run autotap or ease to monitor the 02 values.
Old Mar 19, 2004 | 11:00 AM
Z06ForMe's Avatar
Z06ForMe
I sent you an IM message.
Old Mar 19, 2004 | 11:03 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Removed Cats...LOST TORQUE??????? (Snake Slayer)
:iagree:
Old Mar 19, 2004 | 11:51 AM
C5 CU's Avatar
C5 CU
you can commonly add a considerable amount of timing after removing cats plus general tuning update...can get the low-end torque back.
Old Mar 19, 2004 | 11:55 AM
Red5's Avatar
Red5
Default Re: Removed Cats...LOST TORQUE??????? (Z06ForMe)
I did not recieve your IM.
Im running O2 simms so I can't get a good read from the O2s.
Is there a way to dial inmore timing without having an LS1edit?
Old Mar 19, 2004 | 01:24 PM
BoostManiac's Avatar
BoostManiac
From: Deplorable 160 Proof Olde Anglo-Saxon in Atlanta, GA
This is a common problem with NA motors. You can compensate with tuning. Now with FI on the other hand, you would gain across the range pretty much right away, even more after tuning. :smash:
[Modified by BoostManiac, 12:25 PM 3/19/2004]
Old Mar 21, 2004 | 01:37 AM
wht2000vette's Avatar
wht2000vette
ls1 edit would make a huge difference on the way it runs :)
To Removed Cats...LOST TORQUE???????
