Fast Blinker
Old Mar 20, 2004 | 12:45 PM
Seth's Avatar
Seth
Default Fast Blinker
When I turn my right blinker on, all the sudden it is blinking super fast. Any ideas what is causing this? The left blinker works normally.
Thanks,
Seth
Old Mar 20, 2004 | 12:48 PM
birch64's Avatar
birch64
Default Re: Fast Blinker (Seth)
check the bulb its a 2 filament bulb the turn signal filaments bad replace the buld and see............
Old Mar 20, 2004 | 01:15 PM
Bigben's Avatar
Bigben
I Have the same problem. I believe the turn signal light bulb is burned out and that is what is causing this. Turn the signal on and have someone take a look. Also, there was a good thread a few months back about easier ways to change the bulb if it is burned out.
Old Mar 20, 2004 | 05:42 PM
pinot's Avatar
pinot
OK guys. I have the same issue and changing the bulb did not help. At first it was erratic but now it is permanent. The turn sigs are built in to the hazard control module which I think is immediately behind the hazard switch in the top center dash. Is there anything I am missing here or is time to buy a hazard control unit and tear apart my dash? Thanks.
Old Mar 20, 2004 | 07:43 PM
blackjack's Avatar
blackjack
Default Re: Fast Blinker (pinot)
The blinker assy. itself might be bad. In the old days it was under the dash.
Plug and play like a fuse. I'll look around and see if I can locate it...
[Modified by blackjack, 6:44 PM 3/20/2004]
Old Mar 21, 2004 | 09:08 PM
kirbyloid's Avatar
kirbyloid
Check the bulbs that will cause this
Old Mar 21, 2004 | 10:11 PM
Patches's Avatar
Patches
This has been the case with severl member's cars here. In addition, there was a GM recall dealing with the hazard swithch failure that did not include the C5.
Old Mar 22, 2004 | 01:11 AM
pinot's Avatar
pinot
Patches - Thanks for the input.
Anybody resolved this one yet?
Old Mar 22, 2004 | 03:04 AM
blackbelt's Avatar
blackbelt
Multi function swith replaced by dealer fixed mine when it was messed up. Thats what they called it
Old Mar 22, 2004 | 03:18 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I would have said burnt out bulb too...must be a module. :smash:
Old Mar 22, 2004 | 03:32 AM
Monster231's Avatar
Monster231
Default Re: Fast Blinker (lager99)
Check the fuse box under the passenger footwell, thats where the relay is, that may be malfuncttioning as well
Old Mar 22, 2004 | 04:11 AM
Seth's Avatar
Seth
Thanks for the info. I will check the bulbs first. Hopefully that is the problem.
To Fast Blinker
