Check engine light PCM code
Old Mar 20, 2004 | 04:03 PM
FormerBiker's Avatar
FormerBiker
Default Check engine light PCM code
The check engine light just came on and I got the PCM code P0440 H C.
I know the H is for history and the C is current.
The list of codes posted here has P0441 but no P0440.
Any one have a complete list that can look this up for me?
Thanks.
Old Mar 21, 2004 | 12:20 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: Check engine light PCM code (FormerBiker)
Thanks.
It means the Evap system isn't holding pressure, or the sensor isn't reading the right pressure. 90% of the time it's just the gas cap needs to be taken off and put on again. Give it a bunch of clicks.
Old Mar 21, 2004 | 12:49 AM
kardashim's Avatar
kardashim
i was going through some sode issues myself for the first time. anyway, got some help in the scan and tune section. and found a great website http://www.stengel.net/diccodes.htm check it out!
Old Mar 22, 2004 | 10:19 AM
FormerBiker
Default Re: Check engine light PCM code (kardashim)
Thanks Guys. Turned out that it was the gas cap....DOH!!!!!
I'll mark that site for the codes. :thumbs:
To Check engine light PCM code
