Blackwing installation - need help
Old Mar 21, 2004 | 04:54 PM
vectorz's Avatar
vectorz
Default Blackwing installation - need help
I bought a used Blackwing from a member on the forum. It probably is simple, but are there instructions out there? I want to be sure I'm doing it right. There's a hole next to the 'sensor' on the blackwing. What do I do with that hole?
Old Mar 21, 2004 | 05:03 PM
tekheid's Avatar
tekheid
Default Re: Blackwing installation - need help (vectorz)
That's for the PCV valve. You pull the original valve out of the old air box and plug it into the Blackwing. I had to trim several inches off the PCV hose to make it sit right with the Blackwing. You don't have to do that though. Hope this helps :)
Old Mar 21, 2004 | 05:11 PM
tekheid's Avatar
tekheid
Here is a link that should help . . . . . .
https://www.corvetteforum.com/techti...D=76&TopicID=1
Old Mar 21, 2004 | 05:27 PM
tekheid's Avatar
tekheid
This is even better . . . .
http://www.ls1howto.com/index.php?article=19
Old Mar 21, 2004 | 05:45 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Default Re: Blackwing installation - need help (tekheid)
:iagree:
Be careful disconnecting that MAF sensor plug!!!!!!!..
http://forums.corvetteforum.com/zerothread?id=774271
Here is another recent thread with a few more installation tips and some examples of completed Blackwing installs
http://forums.corvetteforum.com/zerothread?id=774067
[Modified by EB20003, 4:47 PM 3/21/2004]
To Blackwing installation - need help
