Speed Inc. Fuel Rails??????????????
Old Mar 22, 2004 | 01:04 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Speed Inc. Fuel Rails??????????????
Has anyone installed Speed Inc.'s fuel rails??? Opinions and suggestions needed. Thanks Guys! :D
Old Mar 22, 2004 | 02:58 PM
kromberg's Avatar
kromberg
Default Re: Speed Inc. Fuel Rails?????????????? (Bink)
I have them with their sheet metal intake. To mount them on a LSx intake, some type of adapter would be needed.
Keith
Old Mar 22, 2004 | 03:51 PM
cfi_luz's Avatar
cfi_luz
Default Re: Speed Inc. Fuel Rails?????????????? (kromberg)
I have their rails as well and they simply bolt in place of the stock rails on my ls6 intake. If you are going to keep your stock rails you will have to buy their 'install kit' or cut the ridge off your stock feed line and use a tube nut or bushing to adapt the braided hose to your stock feed lines.
Old Mar 22, 2004 | 06:13 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Speed Inc. Fuel Rails?????????????? (cfi_luz)
Thanks Keith!
cfi_luz - the stock rails have that pulse modulator ( I think that's what it is -acts to buffer??) on the cross -over. Do they have a replacement??
Are you happy with yours??
Are you happy with your Exedy??
Thanks!! :yesnod::
Old Mar 22, 2004 | 06:20 PM
cfi_luz's Avatar
cfi_luz
No, there is no replacement for the fuel dampner, but it appears no have no effect other than creating a restriction. I am very happy with the rails, my fuel pressure is much more consistent and it cured the drop in pressure I was having over 6,500rpm. Plus, you can't beat the bling factor ;). I can't comment on the exedy clutch as I have not recieved mine yet. Well, that and I also have no engine in my car right now :rofl: . Let me know if you have any other questions. thanks
Old Mar 22, 2004 | 09:10 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Thanks!
And --->> Well, that and I also have no engine in my car right now :rofl:
......is a classic! :lolg: :lolg: :lolg: :lolg:
To Speed Inc. Fuel Rails??????????????
