2.73 to 3.15 gear replacement (HELP)
The 2.73 to 3.15 upgrade is one that the Chevrolet dealer can handle with their GM programing tool; called the Tech Tool 2.
But this doesn't mean they will still do it. My local dealer quoted me $60 for such a reprog.
BUT, the GM reprog tool can not program in a rear axle ratio that wasn't available from the factory (with the type of transmission you have). And the A4 only came with either the 2.73 or 3.15. The GM programer will not accept entries for any other ratios other than 2.73 or 3.15
The factory PCM has different values in it for the 2.73 and the 3.15 ratios; so the data needed is not already in your PCM now.
Or if you go with a more radical ratio ... say the 3.42 or 3.73 you'll need to go elsewhere (than your Chevy dealer) for a reprog or buy an aftermarket programmer yourself. No matter what ratio you vary from. if you are starting with the 2.73 then you will have to reprog
[Modified by Mike Mercury, 6:39 PM 3/22/2004]
yes, but many Chevy dealers won't mess with this sort of stuff - even though they are capable of doing it.
While I am sure that this is not the case everywhere, just be advised that some dealers may balk.
Perhaps you can answer this for me Mike. Why is programming necessary when going from 2.73s to 3.15 or higher. I understand that one will hit the rev limiter before the car shifts from 1st to 2nd if no programming is done.......but why???? I know I must be missing something here, but it seems to me that the tranny would shift at a given RPM or predetermined speed no matter the rear end. A friend of mine who owns a C4 asked me this and I could not give him an answer.
[Modified by EB20003, 7:48 PM 3/22/2004]
When you reprog a C5 (because of a rear axle ratio change), you enter in new -lower MPH shift points to account for the MPH difference.
and then there's the P1870 PCM "slip error" code to avoid - but that's not related to WOT shifting.
[Modified by Mike Mercury, 9:44 PM 3/22/2004]
Also, my pcm eventually adjusted itself to the new gears. It took a couple hundred miles to do so. I only got the GM reflash for more piece of mind. I could tell a difference though after the new tune. My car is also a 2000 A4.
Adam
[Modified by PewterVette, 3:33 AM 3/24/2004]
[Modified by PewterVette, 3:34 AM 3/24/2004]
[Modified by birch64, 3:40 AM 3/24/2004]
Hope I am making sense.
[Modified by PewterVette, 4:40 AM 3/24/2004]
The only downside when I had this done is that it took a week for the dealership to receive my new 3.15 tune from GM. This was because the guy who usually does this work was out of town. I bet you will not have this problem though.
I'll look in the glove box for my records tomorrow to confirm this but I think the 3.15 tune I got from GM is called a VCI #. Basically, you will get the same tune back from GM that is currently in your car with the only change being your shift points and whatever else is required when going to a 3.15.
[Modified by PewterVette, 4:55 AM 3/24/2004]
No one should be under the impression that the PCM "adapts" or "learns" new values for shift points and so forth. There are some adaptive cells related to pressure and duration, but they work as adjustments relative to a defined target.
You guys having trouble coaxing the dealer into being helpful are taking donuts, right? :jester
I can't explain your outcome. :confused:
So it seems that as long as its not WOT that a shift into second gear is possible assuming the target MPH is reached before the car redlines?
Thanks again.
[Modified by EB20003, 11:11 AM 3/24/2004]
