Tire pressure for the strip?
Old Mar 22, 2004 | 07:16 PM
Trigger Creep's Avatar
Trigger Creep
Default Tire pressure for the strip?
Hey! I thought of another newbie question! A search didn't really turn up anything on this.
I haven't had the opportunity to take the C5 to a drag strip, so I haven't considered this until now.
With the Goodyear runflats, is there an advantage to lowering the rear tire psi? The sidewall is so stiff, I don't know if it would prvide more traction or less.... So, what has your experience taught you guys???
Waiting to do a few Goodyear melts :jester
Old Mar 23, 2004 | 12:38 AM
gary brown's Avatar
gary brown
From: Los Angeles Founder, West Coast Corvette Challenge
Default Re: Tire pressure for the strip? (Trigger Creep)
Trying airing down to about 26 lbs. (no less with run craps) and drive AROUND the water box! :yesnod:
In the future, when you become a true Mod-Aholic like the rest of us, you will want some sticky tires if you like drag racing. :D Hope this helps.
Gary
Old Mar 23, 2004 | 06:39 AM
te51cle's Avatar
te51cle
Default Re: Tire pressure for the strip? (gary brown)
:iagree: Yep, don't bother dropping the pressure much as your times will get worse. Runflats should only be used for ricer burnout competitions in my opinion !
Old Mar 23, 2004 | 10:56 PM
wht2000vette's Avatar
wht2000vette
Default Re: Tire pressure for the strip? (te51cle)
:iagree: :lol:
To Tire pressure for the strip?
