[Help] Charge System Fault
Old Mar 23, 2004 | 08:27 AM
Aviator's Avatar
Aviator
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
Default [Help] Charge System Fault
I was getting this error message on the DIC about once a week and the dealer advised I needed a new battery. So they gave me a new battery. This was about four months ago. I'm still getting the Charge System Fault error message, but now it's only about once a month.
Anyone know what this is? Could the new battery be bad?
Old Mar 23, 2004 | 08:42 AM
dahoof's Avatar
dahoof
Default Re: [Help] Charge System Fault (Aviator)
Check to make sure the battery cables are tight. Also check all grounds for lose connections. What is your voltage?
:cheers:
Old Mar 23, 2004 | 08:57 AM
Aviator's Avatar
Aviator
Cruise-In I Veteran
Default Re: [Help] Charge System Fault (dahoof)
I will recheck all connections.
Voltage is normal - varying between 13.3 to 14.1.
Old Mar 23, 2004 | 11:21 AM
CAPN17's Avatar
CAPN17
Sounds like agrounding problem, either losse or corroded connections.
To [Help] Charge System Fault
