Exhaust Plate compatible with Borla Stinger Exhaust
Old Mar 23, 2004 | 08:00 PM
Bmore50thc5's Avatar
Bmore50thc5
Default Exhaust Plate compatible with Borla Stinger Exhaust
I would like to know if there is a center exhaust plate that will fit the Borla Stinger Exhaust? Are all of the exhaust plates a standard size? I believe the oval tips that come with the Stinger are slightly larger than the stock tips. Any advice or info would be helpful...
:rofl:
Old Mar 23, 2004 | 08:10 PM
H82GOSLW's Avatar
H82GOSLW
Default Re: Exhaust Plate compatible with Borla Stinger Exhaust (Bmore50thc5)
I believe they're all a standard size. I put on my Borla Quad tips (ovals) after the plate and everything fits just fine back there. :cheers:
Old Mar 23, 2004 | 08:27 PM
Cary's Avatar
Cary
:yesnod: This one of those $49.00 exhaust plates behind my Stinger Quad Tips.
Old Mar 24, 2004 | 01:43 AM
C5HellRod's Avatar
C5HellRod
Did mine afterwards, fit fine with the two-tip.
Old Mar 24, 2004 | 07:09 AM
Gonzo's Avatar
Gonzo
Default Re: Exhaust Plate compatible with Borla Stinger Exhaust (UNCC49er)
I think the Corsa Tiger sharks are the only ones that would cover the exhuast plate. I asked a dealer a while back, and was told the Borlas were fine. :cheers:
Old Mar 24, 2004 | 08:19 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Default Re: Exhaust Plate compatible with Borla Stinger Exhaust (Gonzo)
The exhaust plate will fit - It covers the fiberglass piece that hangs down in view. Plenty of room - and WELCOME to the board! Check out the east coast board as well, there is a skyline Drive Cruise coming up April 23!
[Modified by Ragtop_Rob, 7:20 AM 3/24/2004]
Old Mar 24, 2004 | 09:22 AM
wwashing's Avatar
wwashing
As long as you use a stick-on one you'll be OK!
There are exhaust plates that clamp on between to the exhaust pipes. Those are designed to fit specific exhaut systems. So unless you can find one designed for the Borla Stinger, stay with the stick-on kind. :cheers:
To Exhaust Plate compatible with Borla Stinger Exhaust
