Tire Physics Question...which is quicker?
1) What's the equivalent rear end change for a 1 inch tire-diameter reduction? Assume a 3.42 rear to start.
2) Lowering only the rear by 1/2 inch will transfer approximately how much weight to the rear? Will the 51%/49% weight distribution be equalized???
OK you physics geeks...go at it!!
:steering:
1. A 3.57 rear should do the same effect as a 1 inch smaller diameter
2. statically the difference may not be measurable, dynamically I have the following in mind: lowering a car makes the center of gravity go down, on the other hand, raising it, will put the center higher. When accelerating, a higher center of gravity will put a higher moment on the rear tires. Imagine a motor cyclist accelerating: if he sits upright, the front tire will raise when accelerating, so the complete load is on the rear tire. I think he only bends down to avoid a turnaround. So I think for accelerating only, one should not lower as long as the front tires still have contact to the trac to be able to steeer the car. For driving curves you need lowereing toi keep all tires on the ground.
OK, I know answer #2 is worth a big discussion. Maybe I´m wrong with this. But answer # 1 must be pretty good. :D
Frederik
2) I would be dropping the rear only, not the front, with this tire. Would this transfer weight to the rear and how much? Would this be better for accelleration and worse for cornering?
:steering:
:steering:
on #2, I think C5 Frederik's answer still applies. Since you're dropping the rear only, the CG only moves down 1/2 the distance (b/c the weight dist is near 50/50). But the basic idea is the same
As for impact on handling, I think the biggest impact will the change in sidewall stiffness. If you're only changing the rears, they'll be stiffer. It's been a long time since I played with that kind of stuff, but I think stiffening the rear makes the car understeer more (could be backwards)
Consider Straight line acceloration only.
lowering the car at the rear will raise the CG above the rear wheel center.
only dynamic forces will be affected.
If we lower the rear by 0.5inches The increase of the moment arm will be about 0.25 inches.
Assume that SG is 10in above the wheel center
Therefore the increase in dynamic wheel load is .25/10x100=2.5%
That sounds significant, however this increased load will only be effective as long as the power can create dynamic friction (wheel spin) (less than 2 second for a stock C5). I would say 0.05sec decrease in time to get to 30mph. It would be neat if someone had real world experience on this.
but then again I could be wrong.
:steering:
Further my assumption about moment arm being above the center of the wheel is wrong oops, should be above the contact patch, which halves everthing! so the gain should be .025 second to 30MPH (44ft/sec.).
