Need Some wiring help please!!
Old Mar 26, 2004 | 01:53 PM
spirok's Avatar
spirok
5th Gear
Default Need Some wiring help please!!
Hello everybody,
I'm trying to install an auto-dimming mirror on my 1998 c5 and i've get pretty much everything all set up. (I've already seen that one article, but that mirror is different from the one that I bought.) Well anyways, all I need to know is if somebody knows if there is a wire that will supply power only when the ignition is turned on and I need one that's near the passenger side fuse box, and that is not too hard to get to. If anyone knows of such a wire PLEASE let me know, I'd really appreciate it.
Thanks in advance
Spiro
[Modified by spirok, 12:59 PM 3/26/2004]
Old Mar 26, 2004 | 02:17 PM
Katz's Avatar
Katz
Cruise-In III Veteran
Default Re: Need Some wiring help please!! (spirok)
There are two Auxillary power wires near the fusebox on the C5.... actually three. One is black and provides a constant ground. One is Yellow and the other is Red. If I remember correctly the Yellow is 12v and always hot while the Red is 12v and hot only with the ignition. I used these wires to hook up the amp in my 2000 FRC.
There should be an entry in your owner's manual about these wires.
Good luck.
Old Mar 26, 2004 | 03:31 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Default Re: Need Some wiring help please!! (Katz)
:iagree: Tucked up on top or on the left side of the metal box left of the passenger side footwell fuse box. You'll see them - just pull them out and splice into them.
Old Mar 26, 2004 | 04:48 PM
spirok's Avatar
spirok
5th Gear
Default Re: Need Some wiring help please!! (BSiegPaint)
Thanks for your help guys, I really appreciate it. I'm gonna take a look at it now.
To Need Some wiring help please!!
