Help...The motor is stumbling under acelleration
Old Mar 27, 2004 | 02:45 AM
Monster231's Avatar
Monster231
Default Help...The motor is stumbling under acelleration
It was fine all day, then when i put it in sixth gear on the highway i noticed a very slight hesitation, eventually it grew though out the range. Like its starving of fuel. But the motor runs strong. When i stoped i noticed idle was lower than normal and it was dipping a few hundred rpm every few seconds. There is also a ticking noise( like spark plug) when the rpm dips. It feels as though the distributor is out of time, but i know better...
I tried to pull the codes unseccesfully but the check engine light never came on.
What could this be, bad plugs, bad fuel pump, :confused: :confused: :confused:
Sorry for the sloppy spelling
BTW, its a 98 coupe with 30K on the clock, just borlas and an intake
[Modified by Monster231, 7:47 AM 3/27/2004]
Old Mar 27, 2004 | 12:06 PM
SFVetteman's Avatar
SFVetteman
Default Re: Help...The motor is stumbling under acelleration (Monster231)
The problem is most likely bad plugs and/or wires. Under load if the plugs/wires are going bad then it is often easier for them to short out then it is to jump the plug gap :cheers:
Old Mar 27, 2004 | 01:14 PM
BADBLACK99's Avatar
BADBLACK99
I bet it is a burnt plug wire. I would check #7 first back by your brake booster.
To Help...The motor is stumbling under acelleration
