78mm LSX results
Old Mar 27, 2004 | 08:48 AM
robz's Avatar
robz
Default 78mm LSX results
I have a cam only Zo6 that was making 397rwhp. I swapped out the 2x cam for a 3x cam and it made 424 and then added the 78 mm fast and got 433 hp. So for my cam only car I gained 9rwhp on the dyno. Thats all I know right now, I will give more details after I pick up the car.
Old Mar 27, 2004 | 09:15 AM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: 78mm LSX results (robz)
Not bad, I can't wait to see my results going from LS1 intake to LSX.
:cheers:
Old Mar 27, 2004 | 10:08 AM
Blorton's Avatar
Blorton
Thanks for sharing! Nice results. :yesnod:
Dan - getting one of those too.
Old Mar 27, 2004 | 10:10 AM
NJ99FRC's Avatar
NJ99FRC
From: If you can see the car behind you, your not going fast enough
New Hydrolic Cam record.... Now go to the track and back it up! :cool: :cheers:
Old Mar 27, 2004 | 11:16 AM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
St. Jude Donor '03-'04
Damn.....very NICE :eek: :cheers:
Old Mar 27, 2004 | 11:20 AM
jayszo6's Avatar
jayszo6
bad azz numbers for a cam only car!!!! :cheers:
Old Mar 27, 2004 | 11:26 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
When you put a set of heads on that thing you will be over 450 at the wheels and have the perfect balanced C5, anymore than that is useless you already have traction issues on the street and more power than that hooking up at the track will only cost you money in repairs--but I know the addiction so you will probably end up with a 500+rwhp monster like I have that would be eaten alive by your car--if you can't get it to the ground its useless--I wish I had considered more of a balance as 99% of the time I drive my car on the street--Your car sounds great and well thought out congrads and 9rwhp for an intake change is very impressive--I think the 346ci cars could benefit from the 90mm intakes setup, after you swap heads you may want to just buy the top piece and a TB and give it a try it will be another 10 to 15 higher yet--
Old Mar 27, 2004 | 05:22 PM
robz's Avatar
robz
Default Re: 78mm LSX results (NEPTUNEBILL)
I totally agree with you bill on all accounts. I will stick with this setup for a while and only do more if I make it a dedicated track car.
[Modified by robz, 8:11 PM 3/27/2004]
Old Mar 27, 2004 | 06:57 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
:cheers: :cheers:
Old Mar 27, 2004 | 07:31 PM
pdd000's Avatar
pdd000
sounds like a sweet setup :smiliedrool:
Old Mar 27, 2004 | 10:18 PM
Redshift's Avatar
Redshift
Platinum Supporting Vendor
Default Re: 78mm LSX results (pdd000)
Nice! I considered doing the same on our Z06, which is running around 415-420 RWHP (stock cat-back and stock heads) but wasn't sure about it. Still needs some tuning tweaks as well.
For those interested, we have several LSX intakes in stock and ready for immediate shipping. Best price around, too ;) :cheers:
Old Mar 27, 2004 | 10:39 PM
IM QUIKR's Avatar
IM QUIKR
First of all, nice numbers for a cam only car. :cheers:
Now regarding the FAST mod; I know I am going to be flamed here but that's only 2% gain for an $800 mod. or $100 per HP. Is that really great or not so great? Can anyone explain the enthusiasm to almost orgasmic proportions for the FAST intake? It sounds like a lot of sales hype to me.
:beatdeadhorse:
[Modified by drcoffee, 9:42 PM 3/27/2004]
Old Mar 27, 2004 | 11:54 PM
brent eb02's Avatar
brent eb02
Default Re: 78mm LSX results (drcoffee)
ROB !!! AWESOME CAM ONLY #S
CANT WAIT TO SEE IT RUN DOWN THE TRACK
Old Mar 27, 2004 | 11:56 PM
NEPTUNEBILL
Past the first boltons etc 100 per hp is typical--
Old Mar 28, 2004 | 09:25 AM
robz's Avatar
robz
drcoffee:I didnt expect much with the intake and posted to show people exactly what I gained so they can have some more insight in choosing for themselves. Not sure if it worth the $ but thats up to each indiv. I would encourage people to shop around and haggle a bit on these mani's. As bill said, the 78 is upgradable to the 90 in the future by replacing the top piece. After chatting with Julio about these manifolds, I do believe I would have gained more with the 90mm despite what FAST and other dealers say. I'm one who likes things done right away and didn't want to wait for a 90mm.
Old Mar 28, 2004 | 11:01 AM
NEPTUNEBILL
I personally think they should scrap the 78mm and base the 90mm for the smaller inches and build a 105mm or 120mm for the strokers--but then the strokers will have to find a way to get more flow from the heads or switch to other heads--I think Katech or who ever makes the c5r heads should offer a streetable version for the mod heads, little bigger combustion chamber so you can work with 11 or even 12 to 1 CR and more compatible with the existing intake manifold options etc--I am told the c5r heads flow an easy 400cfm which the strokers need--
Old Mar 28, 2004 | 01:41 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I think $100/HP is average in most cases.
[Modified by Z06ufgrad2002, 5:03 PM 3/28/2004]
To 78mm LSX results
Old Mar 28, 2004 | 01:45 PM
big bollas's Avatar
big bollas
Default Re: 78mm LSX results (Z06ufgrad2002)
:thumbs: :cheers:
Old Mar 28, 2004 | 03:20 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
So is there any real comparison between the 78 and 90mm varieties? Obviously, the big cube guys will want the 90mm, but what about us bolt-on 346 guys? :confused: :cheers:
Old Mar 28, 2004 | 03:25 PM
robz's Avatar
robz
Default Re: 78mm LSX results (Umrswimr)
I think you'll eek out more with the 90 but then you have to buy an expensive tb too, and then tuning,etc etc.
