Adding Extra Oil for the Track
Old Mar 28, 2004 | 07:29 PM
MySilver04Z's Avatar
MySilver04Z
Default Adding Extra Oil for the Track
The Owners Manual says to add an extra quart of oil at the track and then to remove it when finished autocross/track driving. What's the best way to remove the oil? Is it possible to take a quart from the oilpan without draining too much?
Old Mar 28, 2004 | 07:32 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Adding Extra Oil for the Track (MySilver04Z)
(in teh case of burning oil or sucking it through the intake) I would just add oil as needed to your car. Under extreme g-forces you can run the engine dry from oil not getting to the pump... the extra oil does help that out... Just take it easy and that will not be a problem for you.
VR :cheers:
[Modified by vetterdstr, 9:54 PM 3/28/2004]
Old Mar 30, 2004 | 07:05 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
I wouldn't do it, just add as you need it... :yesnod:
To Adding Extra Oil for the Track
