Timing Chain Install ?
Old Mar 29, 2004 | 10:16 AM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Default Timing Chain Install ?
Quick question on the install of my new chain.
In removing the stock timing gear from the crank snout I am running to a little bit of hassle - My 6 inch gear puller is to large to get on the gear corretly and my 4 inch puller does not have the reach to get a good grab on the gear. What tricks/methods are you guys using to get this puppy off - the last thing I want to do it gouge up the snout of my crank!!!!!!!
Old Mar 29, 2004 | 10:47 AM
gonbad's Avatar
gonbad
Default Re: Timing Chain Install ? (Ruby6spd)
Take a look at this thread. FLUBYU had the same problem!
Isn't the forum great. :yesnod:
http://forums.corvetteforum.com/zerothread?id=782658
Old Mar 29, 2004 | 10:52 AM
Ruby6spd's Avatar
Ruby6spd
Default Re: Timing Chain Install ? (gonbad)
Thanks for the link - I don't know what I would do without this place
:cheers: :cheers: :cheers: :cheers:
To Timing Chain Install ?
